Question about Panasonic SD-YD250 Bread Maker
The dough doesn't seem to be mixed properly. I can see the yeast particles, the dough is tough and not-elastic. Doesn't seem to have risen. When I put it in a warm place to rise, it seems to rise a little.
  • 433 Answers
Hi, It could be that the paddle is sticking or the belt is slipping. This would cause the ingredients not to be mixed properly. Take the empty pan and paddle out of the machine and see if you can spin it freely by hand. It shouldn't stick. If it does stick then the sealed bearing is frozen and a new bread pan is needed. If everytrhing is fine, then check the belts. Belts and motor are located in base of the machine. Unplug machine before working on the belts. Hank
Posted on Nov 11, 2010
How is the best way to freeze yeast roll dough to cook at a letter date and get a good fluffy and tall roll?
Hello, Anne -
https://oureverydaylife.com/can-yeast-bread-dough-frozen-before-baking-28260.html
(Quote)
For doughs that need two risings, let the dough rise once immediately after you make it. Punch the dough down and shape it into a disc. Put the disc in an oiled plastic bag and freeze it. To thaw it, place it in the refrigerator overnight or set it on the countertop for several hours. Once the bread has come to room temperature and risen, bake it as you normally would.
(End quote)
Best wishes.
Apr 15, 2018 | Cooking
What is spiral hook dough?
A Spiral Hook Dough Hook is one that is used for making bread dough. It mimics the action of stretching and kneading the dough by hand. This develops the gluten content which is the elastic part of the dough that traps the bubbles of carbon dioxide from the yeast.
Oct 14, 2017 | Food Mixers
Why have my last two loaves not risen properly?
recheck the yeast as loaves that fail to rise is a yeast problem
Sep 25, 2016 | Kitchen Appliances - Others
Panasonic breadmaker suddenly producing loaves that haven't risen properly
I would watch it run through a proofing cycle to see if it is operating correctly. Make sure it's not getting too hot and killing the yeast and it runs the correct amount of time. It would be wise to make sure the mix/kneading cycle is working correctly too.
Jun 23, 2016 | Panasonic Bread Maker
Dough doesn't rise
Yeast is likely too old, buy a new one and try again - if it works, toss out the old yeast. If the results are the same, your unit is bad. Is it getting warm/hot while operating?
Mar 29, 2012 | Black & Decker Bread Machine
The bread starts rising and than falls in the middle in the last 20 minutes of baking. What is wrong?
Rising bread is caused by carbon dioxide bubbles being created in the bread by the action of yeast on the sugars in the mix. If the rising stops early, allowing the bread to fall it could be one of several things that cause the carbon dioxide bubbles to stop pushing up the bread. Any of the following could be the cause:
- insufficient sugar in the mix to feed the yeast.
- sudden drop in temperature, slowing down the process, maybe caused by opening the lid to check
- mixture that is so thick that the gas production struggles to overcome the elasticity of the dough
- try adding a little more water, or more sugar, or changing the flour. Avoid opening the machine to check on progress.
Mar 05, 2011 | Sunbeam 5891 Bread Maker
When I first got my breadman I made several loves of the basic white recipe using Pamela's gluten free bread mix. They all turned out fine. Then I started experimenting with the other recipes provided. ...
Without knowing the specific ingredients in your recipe and having no experience with gluten free flour I am basing this on what I know about bread makers in general. I have owned dozens!
1) If the onion spice you are adding is something like a mix (onion soup mix for example) then you may get better results if you cut back on the salt by about 1/2. Also, next time when your machine starts the rapid knead (after the beginning slow knead) if the dough looks like batter instead of a dough ball add about 1 tablespoon slowly trickled in over about 10 seconds. Watch the dough ball and see if it starts to look a little dryer. The goal is to not have the gooey batter on the bottom of the pan. The slow addtions of flour will do that for you. If this works please leave a testimonial. I like helping fellow bread machine makers and getting feed back! Best of Luck with your next effort!
Oct 31, 2010 | Breadman TR875 Bread Maker
My bread does not rise properly. Is it possible\r...
If the machine is heating the element is working.
If it looks like bread dough then the paddle is mixing.
It's more than likely your ingredients. Old flour, old yeast, not enough flour, not enough yeast, water too hot or cold.
Check each ingredient to the recip as you put it in. Put them in in the order suggested by the recipe. The yeast should go in last and shouldn't have contact with the water until mixing starts.
May 17, 2010 | Kitchen Appliances - Others
The pin that holds the mixer to the stand keep working it's way out when I mix dough.
Hi, Mixing Dough is tough. the neading hook really works hard and the pin will like to wander out on the left side of the mixer "right side if your facing the it". What I did was find an smaller elastic band and with the pin sticking out a 1/3 of an inch from the opposite side from which it wanders out.
loop the band on it as many times as possible so its stays on tight . with this you now have a bumper and as the pin vibrates to wander out the elastic bumper will gently keep pulling it back during the vibration cycle keeping it in check .
Works perfect but still inspect the pin and bumper before each use.
Mike
Aug 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Panasonic SD-YD250 Bread Maker Logo
224 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Colin Stickland
Colin Stickland
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
