Question about Dewalt 3800 PSI Pressure Washer
If the pump is broken, should the engine start? if i choose to rebulid pump where do i find the torque values/guidlines for the pump. i have to get the model #, but i do have the dewalt 3800 psi model. purchased 2 yrs ago.
    President:
  • Dewalt Master
  • 1,407 Answers
If the engine turns rather freely and not hindered by malfunction of pump, then it should start. Since you are going to rebuild pump, you should just remove the pump from the engine now and set it on the work bench to prevent any further damage. It is a good idea to test engine before you spend any money on the pump. Dewalt service center has all the parts lists for your machine, however you should look up the model number of the pump itself (stamped / tagged on body of pump) and look for more information from mfg. web site. Good luci
Posted on Nov 11, 2010
2005 Buick Lasabre 3.8 engine. Engine light stays on,had it checked,code C1276 came up.In layman terms what can the problem be? Thanks
C1277
Requested Torque Signal Circuit Malfunction
EBCM
DTC C1277 or P0856 in Antilock Brake System
The electronic brake control module (EBCM) and the powertrain control module (PCM) simultaneously control the traction control. The PCM reduces the amount of torque supplied to the drive wheels by retarding spark timing and selectively turning OFF fuel injectors. The EBCM actively applies the brakes to the front wheels in order to reduce torque.
The EBCM sends a requested torque message via a pulse width modulated (PWM) signal to the PCM. The duty cycle of the signal is used to determine how much engine torque the EBCM is requesting the PCM to deliver. Normal values are between 10-90 percent duty cycle. The signal should be at 90 percent when traction control is not active and at lower values during traction control activations. The PCM supplies a pull up voltage of 5 volts that the EBCM switches to ground to create the signal.
The PCM sends a delivered torque message via a PWM signal to the EBCM. The duty cycle of the signal is used to determine how much engine torque the PCM is delivering. Normal values are between 10-90 percent duty cycle. The signal should be at low values, around 10 percent, at idle and higher values under driving conditions. The EBCM supplies a pull up voltage of 12 volts that the PCM switches to ground to create the signal.
When certain PCM DTCs are set, the PCM will not be able to perform the torque reduction portion of traction control. A serial data message is sent to the EBCM indicating that traction control is not allowed.
Conditions for Setting the DTC
C1276
One of the following conditions exists:
• The EBCM detects that delivered torque signal is out of the valid range.
• The EBCM does not receive the delivered torque signal.
Diagnostic Aids
The following conditions can cause this concern:
• An open in the delivered torque circuit
• A short to ground or voltage in the delivered torque circuit
• A wiring problem, terminal corrosion, or poor connection in the delivered torque circuit
• A communication frequency problem
• A communication duty cycle problem
• The EBCM is not receiving information from the PCM.
• Loose or corroded EBCM ground or PCM ground
Install a scan tool.
Start the engine.
With a scan tool, observe the Delivered Torque parameter in the DRP/ABS/TCS data list.
Does the scan tool display the specified value?
May 07, 2018 | Buick Cars & Trucks
What must a Tata Telcoline head be Torqued.
When doing major engine work a shop manual is essential, as it is not just the torque value, but sequence that is important. Further, many newer engines use head bolts that must be replaced, and torque values now may include degree angles for final tightening.
Jun 13, 2016 | Tata Cars & Trucks
Need service information to conduct a thermostat replace ment on a VY series 2 commodore which has the supercharged buick 3.8 engine
Sorry Graham, it is based on a Buick, the big difference is your 3.8 does not have a distributor at all, no where for it to go even, you have to start with your fan belt using a 3/8 drive bar that fits into the flexible belt tensioned, then remove ALL the plastics from the front of your engine, the water pump is under them, not a nice job so I would look at replacing any belts bearings and seals as you go
Dec 29, 2013 | Holden Cars & Trucks
I need the torque settings for a HD 1450 motor
If you need the torque values for a particular item, I may can provide that but I cannot provide ALL the torque values for the engine as there are quite a lot of them. If you need that level of information, I'd suggest the purchase of a service manual. I understand that coming to this site is to obtain information but I simply do not have all the torque values for these engines. I specialize on the older engines like the Panheads, Shovelheads, Ironhead Sportsters and the Evolution. I do not work on Twin Cam engines but some of the torques values are the same and I can provide those. Other setting, particular those in the cam chest, I do not have. Sorry.
Good Luck
steve
Jul 08, 2011 | Harley Davidson Multistada 620 Dark...
Having trouble getting my car started and keep it running
  • ;-------------------------- open up your hood and look for the idle and adjust it carefully little by ==============little and try starting your vehicle but if not, have your battery test first-------------------------------if it is producing enough voltage. ( battery maybe dead) . also try buy new sparkplugs and install it follow guidlines for torque tighting. also other option is distributor cap .
Jan 10, 2011 | 2000 Mitsubishi Galant
Instal water pump
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the engine cover.
  5. Remove the accessory drive belt.
  6. Remove the idler pulley.
  7. Remove the crankshaft pulley.
  8. Remove the power steering pump pulley.
  9. Remove the tensioner pulley.
  10. Remove the upper and lower timing belt covers.
  11. Remove the No. 3 engine mount.
  12. Remove the timing belt.
  13. Remove the timing belt tensioner.
  14. Remove the water pump.
  1. Installation is the reverse of the removal procedure, while using the following torque values:
    Water pump bolts: refer to the illustration Crankshaft pulley: 130-138 ft. lbs. (180-190 Nm)
3.8L Engine
  2. Record the radio anti theft code data.
  3. Drain the cooling system.
  4. Disconnect the negative battery cable.
  5. Remove the accessory drive belt. Remove the water pump pulley.
  6. Remove the water pump retaining bolts. Remove the water pump from the vehicle.
To install:
  1. Installation is the reverse of the removal procedure.
  2. Reprogram the radio anti theft code data.
  3. Be sure to use a new water pump gasket. Torque the retaining bolts to 16 ft. lbs.
  4. Torque the water pump pulley bolts to 6 ft. lbs.
  5. Be sure to refill the cooling system with the proper grade and type coolant. Start the engine and check for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2004 Kia Sedona
P0741 problem
P0741 Torque Converter Clutch Circuit Performance or Stuck Off they should fix all of the problems
Mar 25, 2010 | 2005 Toyota Corolla
Audi A6 2.4 2005 just over 100000km it need to change timing belt or it run chain. thank's
2.4 not such a thing. You mean 4.2 right?? You must chnage timing belt water pump and all related probably bout 1600.00 . Much cheaper that an engine rebulid work. If belts breaks vakves will bent
Mar 04, 2010 | 2005 Audi A6
Dewalt 3800 PSI Pressure Washer Logo
218 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
