Question about Whirlpool GGW9868K Gas Dryer
My gas dryer started beeping intermittantly while not in use. When I went to check on it, the lights for the towel setting were on (which was not even the last setting used). When I pushed the stop/cancel button, it beeped and came back on as soon as I let it go. I called the Whirlpool 800 number on the dryer and asked for troubleshooting help. They told me to cut the power and leave it off for several minutes, explaining that it should reset the computer in it. I unplugged it and left if off for quite awhile (did not time it). When I plugged it back in, it stayed off for a few minutes. I was even able to dry a couple of loads of laundry today (one of which was towels), however, it keeps doing the same thing--lighting up on the towel setting and beeping even when not in use. The last time I tried unplugging it, it did not work. The lights came right back on as soon as I plugged it in, and now I cannot even get it to change settings. I can't dry everything on high heat. Do you think it is worth the cost to call in a repairman, or am I looking at buying another new machine. This one is probably only about 6 years old. I had my previous dryer for probably 16 years.
  • Whirlpool Master
  • 2,816 Answers
I say it depends what its going to cost to repair. I had a dryer that worked twenty years and when I replaced it they told me I would be lucky to get eight to ten years out of a new one. Its a throw away society now days.
Posted on Mar 03, 2017
catriver
  • 878 Answers
SOURCE: Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Posted on Aug 10, 2008
SOURCE: Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Posted on Sep 27, 2008
SOURCE: I HAVE A WHIRLPOOL DUET
We had the same problem. Sometimes unplugging it for a few days, it would work when plugged back in. We replaced the user interface which is part #19 on the Whirlpool parts list, the front circuit board. The part alone was $160 at the cheapest place we found. http://www.appliancepartspros.com/
Posted on Feb 11, 2009
lenwest
  • 150 Answers
SOURCE: I am using my towel setting but my towels are still wet
Sounds like you have lost part or all of your heating element.It should be replaced.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 16, 2009
  • 289 Answers
SOURCE: Doesn't dry clothes. New Just installed 11/16.
try running dryer with out hooking up the vent line.if it work's than your problem is with the vent line.
Posted on Nov 17, 2009
We have a Frigidaire gas dryer about 2 yrs old. I placed a load of towels to dry (at "Towel" setting) everything went fine. I placed the next load and chose "Normal" setting. The...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2011 | Frigidaire Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer starts up for less than a minute and than starts beeping and all lights start flashing. For a while i was able to change settings from 60 mns to towels and it would work. Now it starts for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2010 | Dryers
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Gas dryer burner intermittently lights. Foul gas
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
Dryer won't get hot
sounds like your igniter went out. you can test it by locating the igniter,unplugging it and use a volt meter to check the continuity(the setting were it beeps when you touch the pos.and neg.prongs together).If it has current (beeps) going through it than it is good.
Nov 25, 2008 | Maytag Dryers
Strange beeping noise
I read on another site that if the indicator on the dash is malfunctioning and there's a fault code in the system, the beeping is a secondary indication that there's a need for service. I've had my air bag light blinking for some time now. Yesterday my gauges went out, Oil Pressure, Gas Level, Temp Level, and the Battery Charging Meter, all went dead. After starting the vehicle, it beeps 5 sets of 5 beeps. Since the dash obviously has problems, (Including the Air Bag blinking thing not working), the beeps I now hear are what you are experiencing. However, if you still see the air bag light blinking, maybe your situation is a bit different than mine.
Jul 22, 2008 | 1994 Ford Aerostar Extended
Main flame does not stay on or does not come on
THE CHATTERING SOLENOID IS FAILING INTERMITTENTLY AND NOT OPENING UP THE GAS VALVE. REPLACE THE SOLENOIDS AS A SET. THEY USUALLY COME PURCHASED AS A SET.
Apr 22, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore HE2 Dryer makes three beeps but wont start
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Mar 22, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Dryer
try new gas valve coil packs. They are inexpensive, easy to install and fix 90% of intermittent lighting complaints.
Oct 15, 2007 | Dryers
Whirlpool GGW9868K Gas Dryer Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
