Question about Emerson LC320EM8 32 in. LCD TV
I have a emerson model # lc320em8 and there are vertical lines on the screen. there are about 4 or five close together at the middle right of the screen along with 5 or six more in other areas of the screen.
  • 1 more comment
  • mike rondeau Nov 12, 2010
    when you say panel do you mean the screen itself or a control panel?
    the screen is not broken as far as i can see. i did get the tv for free. is it possibly the t con?
    I understand that there is an issue with the lcd panel. I got the tv for free and would like to try to fix it. If there are no cracks on the screen is it possible there may be a ribbon cable or somehow I can attempt to fix it?
  • Emerson Master
  • 19,396 Answers
Hi.
If lines are shadows, then problem is the backlight system, which is included with the LCD panel.
If lines are well defined, then problem is either LCD panel or main digital board. T-Con board must also be tested before replacing the main board.
Here all parts for this model.
Here service manual at $2.99
Regards.
Ginko.
Posted on Nov 12, 2010
  • 10,515 Answers
I'm afraid this doesn't sound good.The other expert is correct in the diagnosis.
I'm guessing these lines are there regardless of which input you select or what screen format you select, correct?
And these lines never move from one part of the screen to another, they are always in the exact same position, correct?
And if you press the TV's MENU button (not a cable or satellite box menu), the lines interfere with the menu, correct?
I wish I had better news for you, but if those lines show up in exactly the same place every time on all inputs and formats, the problem is the actual panel (the screen) itself.
Unless this is under warranty, this is going to be a major expense to fix, and is precisely why I urge anyone who buys a current technology HDTV to get an extended warranty. All of these TV's, regardless of whether it's plasma, LCD, or rear projection, have large and expensive assemblies that cannot be fixed, and must be replaced.
Definitely get an estimate from a tech, but be prepared for a real shocker.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • 4,472 Answers
Assuming it doesn't matter what input your on and the lines are always there. This is a sign of a problem with the LCD panel itself which is the most expensive part of the television. Given the age and brand of the tv your best bet will be to sell it for parts on ebay /craigslist to recoup some of your costs and replace it with a more dependable model from a more reputable manufacturer. Anytime you are making a new electronics purchase make sure to research them all very thoroughly on the internet. Most times you can avoid lemons or problem prone models by researching before buying. if you need further assistance please let me know. If you find this information helpful please take a moment to accept/rate it accordingly.
Thank you,
lee
Posted on Nov 11, 2010
  • Lee A.
    Lee A. Nov 12, 2010
    The screen itself is referred to as the lcd panel.
    Thanks,
    Lee
  • Lee A.
    Lee A. Nov 12, 2010
    The screen doesn't have to "appear" broken. The lines can and most likely are a sign of a failed panel. Especially given the manufacturer and the age of the model. Please reconsider and accept/rate my assistance accordingly and I would be glad to continue assisting you if you need any further assistance.
    Thank you,
    Lee
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
A red vertical line that doesn't go away. Is it a tube or what. TV is about 3 yr. old.
A LCD does not have any tubes in it and the red vertical line is a driver in the TV that has gone bad.
Jul 22, 2011 | Emerson LC320EM8 32 in. LCD TV
Black vertical lines lc320 emerson
I'm sorry but this is a symptom of an internal problem. You will need to reference a TV repairman.
Jun 15, 2010 | Emerson LC320EM8 32 in. LCD TV
Is there a difference in the screens for a emerson lc320em9 and an emerson lc320em8
The manufacturers will use any screen they can get their hands on depends on the price they willing to pay for, you can have same model number with difference LCD panel brands inside. This is a common practice. You can have cheaply made CHI MEI screen or good LG/PHILIPS, or Sharp LCD panels inside your TV. CHI MEI wil be more likely.
Dec 22, 2009 | Emerson LC320EM8 32 in. LCD TV
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
Emerson LC320EM8 32 in. LCD TV Logo
326 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
