Question about Dremel Garden
Have a 4"blade dremel small
  • 7,733 Answers
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or Dremmel.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
Need blades for Dremel Moto Saw 57-2==do you know where I can order any?
Home Depot; Lowes; Amazon; google search for more.
May 10, 2015 | Dremel Saws
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
HOW DO I OIL THE DREMEL 1830 SCROLL SAW?
  • page 15 Squirt a generous amount of SAE 20 oil around the shaft end and bronze bearing
  • Dremel 1830 Manuals
Sep 16, 2014 | Dremel 1830 120V 18" Scroll Saw
I have an old Dremel scroll saw model 550 and need blades. However, the blade holder is missing a clamp that secures the blade. Is there a universal kit I can purchase to solve problem?
Try going to a store that sells scroll saws and look at the new models to see how they hold the blade. Take your Dremel with you. Maybe you can find one that is similar enough that could work if you can get the part. Then go to the tool company's web site and search for the manual for the comparable tool you found - they all have on-line manuals nowadays. You should be able to order the part you need. Good luck!
Jan 30, 2013 | Dremel 5 3" Saw Blades 8033 For 550...
I started to "SMOKE" through
Don't want to state the obvious but is the blade on in the right direction?
Aug 27, 2011 | Craftsman 10" Table Saw
The pot metal in front of thequick release tension lever has broken and fell out. can I still use the saw If not where do I go to get another one 1830 120v 18inch scroll saw dremel
I believe the part you are looking for is called a "locking rod" dremel part number 2610922661, this is the black painted pot metal that is about 3" long attached to the upper arm rocker with a parallel pin, and the flip clamp (blade tensioning assembly) or it could be the small piece attached to the tension assembly that the blade attaches to which is silver and called the "blade holder assembly-top" part number 2610922683. I would recommend ordering both directly from Dremel CS 1-800-437-3635. I broke the locking rod on mine. I emailed dremel, and they emailed me back the next morning with a schematic, and parts list. I bought 2 and paid $10.41 total.
Mar 08, 2011 | Dremel 1830 120V 18" Scroll Saw
Have a Craftsman 10" Model 113.241691 table saw
I have the same table saw. Mine has done that for the past 25 years and I've always considered that it's just the flexible shaft coming up to speed. It's never given me any problems so haven't looked into any further.
Dec 20, 2010 | Craftsman 10" Table Saw
My saw problem has to do with changeing the blade. I'm useing a thin kirf blade. When I change the blade I have to put a wrench on the arbor next to the pulley to keep the arbor shaft from turning when I...
The nut is binding on the arbor because the threads are buggered up or clogged with something. It could be the nut (which is probably brass and soft) or the arbor (which is steel). If it got a little cross threaded, the damage will be on the nut. It might be the arbor if the arbor took a whack. Once you have it apart you should be able to see it - although the damage might be pretty small. You aren't likely to have a tap and die to run through the threads, but you can probably fix it with a little rotary tool (like a dremel) using a small disc. If it is the arbor you can use a triangular file. Or you can buy a new nut. I hope this helps.
May 17, 2010 | Craftsman 10" Table Saw
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Oct 22, 2008 | Dremel 16472 Carbide Coated Scroll Saw...
Garden Logo
79 people viewed this question
Top Dremel Garden Experts
Clyde Ottaway
ray gallant
Are you a Dremel Garden Expert? Answer questions, earn points and help others
