Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Error #100 vsa - HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
    Genius:
  • 1,570 Answers
Uninstall and reinstall the printer software
Posted on Nov 11, 2010
V0122 (126-4) Permanent DTC F-CAN MALFUNCTION (ECM) PCM - VSA CONTROL MODULE UNIT) but no Service Engine light
no communication between VSA module and ECM, Check wiring, fuses, or vsa module. If vsa module it may be costly. VSA is the ABS/Trac control. Can you pull codes from vsa are the lights for vsa (ABS) coming on in the dash?
Feb 03, 2018 | Acura Cars & Trucks
I have Acrua TLS 2003 the VSA Light is on what does that mean
VSA is vehicle stability assist. I don't know whether light indicates vsa is on or faulty.
Jun 17, 2015 | Acura TL Cars & Trucks
My 2008 Honda accord is displaying an explanation point on dash what does it mean
If the explanation point is inside of what looks like a tire. Tire Pressure Monitor System. Inflate your tires to the correct pressure (probably 32psi) Or could be an issue with you TPMS
Jul 28, 2014 | Cars & Trucks
How do you reset the vsa light on 01 acura CL type S?
of vsa is user disable-able at all. it's stated so in the users manual
did you look there first?
lost it?
Jul 15, 2014 | 2001 Acura 3.2CL
VSA shows on my dash and the vehicle seems to remain in the same gear. It can't accelerate after the car has been slowed down. The error message can only be reset when the engine is switched off...
"VSA" stands for "Vehicle Stability Assist". This system has four indicators: The ABS indicator, the VSA indicator, the VSA activation indicator and the Brake System indicator.
When the system detects a malfunction, it illuminates the appropriate indicators. Depending on the failure, it determines which indicators to illuminate.
These lights illuminating do not necessarily indicate a failure in the VSA system itself. The VSA is only PART of the computer network in your vehicle. Information is shared among several control units. Certain malfunctions in the engine control or transmission control systems can cause the VSA to be disabled and the warning lamps will illuminate.
The only way to determine the cause of the problem with your vehicle is to perform a computer network scan to find out the nature of the failure and which control module requested the VSA to be disabled.
Apr 13, 2012 | 2004 Acura MDX
My VSA light is on and I'm told the only people who can turn it off is Honda, but Honda won't even look at my Pilot without charging me $100 plus dollars up front. I had brake pads, etc. replaced at...
I'd check around with some of the specialty shops, the dealer is not your only choice. I doubt they'll do it free but probably cheaper than Honda. VSA is your Vehicle Stability System.
Mar 04, 2011 | Honda Pilot Cars & Trucks
My 2005 Odessay Touring van has a VSA light that has gone on about ten times today. Each time I have to turn off the ignition and turn it back on in order to make it go official. However only once did the...
Thanks for the info... that fixed the problem with the VSA light going on. The error code had nothing to do with the VSA system. Error code said I was low on oil. The dealer I brought it to said the VSA system will not work when you are low on oil. When the VSA warning light comes on, you loose 80% of your engine power because of it. They changed the oil and I have not had the VSA warning light go on since.
Feb 06, 2011 | 2005 Honda Odyssey
My vsa system indicator and vsa activation indicator light came on and it will not go off even when I turn off and on my honda- what does that mean?
It's hard to said what it is without a VSA code, but the VSA system monitor the rotation of you tires. Check and make sure you have the same tire size for all four tires. If the tires are not spinning at the same ratio could cause the VSA light to come. It could be a bad sensor or even the VSA modulator itself. It's hard to said. Good luck
Dec 15, 2010 | Honda Odyssey Cars & Trucks
2006 Honda crv, vsa, abs, and triangle light are permanently on
You are talking about the VSA activation indicator (triangle with exclamation point in the middle):
This indicator has three functions:
It comes on as a reminder that you have turned off the vehicle stability assist (VSA) system.
It flashes when VSA is active.
It comes on along with the VSA system indicator (the rectangle with VSA in it) if there is a problem with the VSA system.
This indicator normally comes on for a few seconds when you turn the ignition switch to the ON (II) position, and when the ignition switch is turned to the START (III) position.
Hope this helps you understand the problem.
Dec 09, 2009 | 2006 Honda CR-V
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
165 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
