Question about Electric Mobility Merits Mp1 Folding Electric Wheelchair
The first battery light keeps flashing when I turn on the control. I believe it is locked, but I have no idea how to get it unlocked. It is a Merits MP1 electric folding wheelchair.
  • 692 Answers
If you are getting just the red light blinking then the batteries are low and not fully charged. If you have been charging and are still getting just the one blinking light then either your charger is not working or you have bad batteries. Hope this helps
Posted on Nov 12, 2010
Merits wheelchair 2 center flashing lights when turned on
Flash Code 2 indicates that the voltage is too high or too low. Check batteries and cable connections. Charge the batteries. If this fault occurs during battery charging, the charger is defective or not adjusted correctly. Empty batteries will charge. Dead batteries will not normally charge.
Feb 26, 2013 | Electric Mobility 24 " Seat Merits Heavy...
Hand control flashes right to left on my merits power chair
Your joystick is in lock mode. Call Merit to find out how to unlock it or a power wheelchair dealer.
Nov 23, 2012 | Electric Health & Beauty
The chairs lights are flashing from right to left on the joystick which is call the sleep mode can not get it to reset.
Hi to unlock the shark joystick turn on the chair and press the horn button twice within 10 seconds of turning it on. This should unlock it for you. Hope this helps
Jan 23, 2011 | Electric Mobility 24 " Seat Merits Heavy...
I have a hotpoint aquarius extra washing machine. The door will not unlock, I have turned it of over night and it still doesn't unlock. I have checked that the water has drained and unblocked a sock from...
This would suggest that the lock is getting a signal from the control board telling it to stay locked, which would explain why the "spin light" is on as the control board does believes the cycle has not finished its in your signal board sorry
Dec 05, 2010 | Washing Machines
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jul 15, 2010 | Health & Beauty
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Shoprider- wheelchair will not move-Lights keep flashing
This usually occurs when either the battery charger is still plugged in when the button is pressed to turn on the wheelchair, or if the joystick has got 'Locked'. On the majority of electric wheelchairs you can lock the joystick control so that the wheelchair cannot be moved, for instance, it it was left outside a shop. You would need a manual for the controller from the manufacturer to tell you how to unlock it. You should be able to find this online somewhere. Most controllers on shopriders are made by Penny & Giles (P&G Drives Technology). Hope thats helpful to you...
Feb 24, 2010 | Electric Mobility Shoprider Electric Power...
The security on my 1993 Grand Cherokee will not turn off
I may be able to help if you havent fixed it yet. I believe I had the same/similiar issue...
I would make sure all of the doors were locked with auto lock button on inside of door, then I would shut the door so all doors were locked from pressing the inside auto lock button. then I would use my key to unlock the trunk, open the trunk and close it leaving it unlocked. then i would use the key to unlock the drivers door and the security would reset... if not then unhook the battery for a few minutes then hook back up and see if that works.. glgl
Mar 10, 2009 | 1993 Jeep Grand Cherokee
Key fob not working
hello mate.. if it has stopped working you might want to check the battery first.. if you are sure that the battery is fine then consider reprogramming the fob to your car.. here are the steps to follow.. NISSAN
Remote Control Fob Procedures:
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure:
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key's for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
Jul 28, 2008 | 2005 Nissan Sentra
Electric Mobility Merits Mp1 Folding Electric Wheelchair Logo
362 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
