Question about Clarity C430 Cordless Phone
The phone rings and when you answer it no one is there and there is no sound and this happens several times in a row. Then after several tries you answer it and the connection is made. We replaced the battery hoping it would fix the problem but it is still doing it.
My phone rings only once or not a complete ring. if I answer it at 1 ring i can connect with the caller, otherwise it disconnects them we have been away for several months. the first day back it...
First try dialing 73#. Also try *73. Depending on you phone company, one of those will cancel call forwarding if it was inadvertently set. If that doesn't solve your problem unplug any answering machines or cordless phone base units that have an answering machine built in. Also unplug any fax machines or computers that are connected to the phone line. If this solves the problem you can plug things back in one a t a time and test to see which item is the culprit.
Apr 17, 2010 | Lands Phones
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
Dail-up server doesn't answer from my home phone
What if you dial the same phone number from your phone instead of the computer. Do you get a ring...static sound? It could be a problemw ith your phone provider
Mar 09, 2009 | Dell Latitude D600 Notebook
Wont accept incoming calls
this happened to mine , I never had aproblem before than one day ??? didnt work . I changed phone jacks ?? dont know why ??
1. Try disconnecting all phones in the household except the phone being affected.
2. Do a test call to see if the unit rings.
3. If the phone rings at this time, begin reconnecting all the other units one at a time. If the affected phone does not ring again, this is an indication that there are too many phones in the loop.
4. If possible try testing the phone on a totally different phone jack (friends or neighbors) to check if the same thing happens.
Also make sure the phone is not connected through an external answering machine, caller ID box, fax machine, computer, splitter, or defective DSL filter. If so then connect the telephone cord directly to the telephone jack and make a test call.
Jun 30, 2008 | Uniden Cordless Phone
Cell phone problems
Sim cards are usually very reliable but seeing that you have changed the phone and still the same result then I would try replacing the sim.
Does this prob occur only when you are one place IE ( work or home) or doeas it happen all the time?
Nov 06, 2007 | Nokia 1100
Clarity C430 Cordless Phone Logo
183 people viewed this question
Top Clarity Lands Phones Experts
Gil Shultz
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
