Question about Toshiba TDP-TW90U Multimedia Projector
Loud humming on my TW90. I'm assuming fan problem but how easy to check/fix?
  • 20 Answers
There should be a small removable grill with a filter. Try cleaning the filter before you fix anything else. If it is a foam filter, you can clean it with soap and water. Make sure it is completely dry before reinstalling. If you have a paper filter, just blow it off.
Posted on Nov 11, 2010
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
It makes a loud humming sound on drivers side
I am assuming this is while you are moving,not parked.
If you drive at about 40 on a smooth road,and "weave" left and right. Does the noise get noticeably quieter one way than the other? If it does ,it's a wheel bearing assembly. Easy fix (I'd change both if thats the case)
If the noise doesn't change,it has to be a transmission bushing or final drive noise,not good.
Hope this helps.
Apr 07, 2011 | Pontiac Montana Cars & Trucks
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
My Acer Aspire One AOA150 's fan is very loud and warm
I'd suggest that you carefully pull the base of your Acer apart - taking out the screw, and keeping track of them. See if your fan is dirty - I have an Acer as well, and if it's dirty, it get loud, and HOT!
A quick cleaning does wonders!
Feb 15, 2010 | Acer Aspire One AOA150-1784 Netbook
Sears 92 gas furnace noise when not in air handling mode
a very subtle hum or buzz is normal and is the transformer that creates 24 volt control voltage continually. some are noisier than others . sometimes a tap or bending of the transformer will tweak the metal enough to make it quieter. they can also get loud if incoming voltage is not correct. incoming 120 volts on a furnace is not usually a problem but the transformers are usually wired to the available incoming 230 voltage or 208 voltage if it is a heat pump or electric heat. If it is powered by 230 or 208 volts as most heat pumps are ,then you need to verify which you have and connect the appropriate leads from the trans former to power . it tells you on the side of the transformer which to connect to 230 and which to connect to 208. tape or cap off any unused leads.since you have not mentioned any performance problems i assume the fan does come on when called for and that it is not the loud hum you hear. switching the fan switch at stat to on should bring the fan on right away. if it doesn't then you may hear a loud hum and then youll need to check the fan motor and capacitor. but it sounds like a noisey transformer from here.
Oct 28, 2008 | Heating & Cooling
Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Sep 02, 2008 | Sharp R-1460 Microwave Oven
Toshiba TDP-TW90U Multimedia Projector Logo
60 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
