Question about Intel D945GPM Motherboard
I powered up the board. all fans lights came on for about 4 seconds also only had ram/ processor hooked up
    Scholar:
  • 105 Answers
Hi.
the problems lies under the fixing your processor.
Remove processor. replace it again carefully. remove mouse and keyboard. remove any PCI and AGP etc.
Start the pc " POWER ".
If it continues doing the same, - no sweat,,,
Check for a new Processor and replace ram as well.
Start the pc. "power".
If success comes up. then by that time you would have the solution.
plug keyboard and mouse..
Start the computer and enjoy.
Good Luck
Posted on Nov 11, 2010
ThinkCentre model A2U; type 3429, s/n MJFEW89, power button slowly flashes, optical drive light flashes 1 short, 1 long every 4 seconds; fan not running; lcd is blank
ThinkCentre Desktops are very picky about installation of every part. (Your replacement RAM was probably too fast, such as 1600 instead of 1333.) Also, the long product ID numbers on the RAM chips must match.
First, WITH POWER DISCONNECTED, ensure the RAM is seated properly. If the RAM sticks are different brands, switch them in the RAM sockets. If you have 4 sockets, socket 0 (is the first socket) is nearest the processor socket.
OR
Remove the RAM and clean the gold fingers with a soft, lint free cloth. Then use compressed air to ensure no debris is removed from the RAM sockets on the mother board.
BobB
Dec 22, 2016 | Computers & Internet
Power fan ok board not display processor not run
1. Make sure that the processor is correctly inserted into the slot. 2. Make sure that all the RAM modules (long sticks with little rectangles on them) are inserted correctly, and completely locked into place. 3. Make sure that the processors fan is working (if it overheats, it may have an auto function to turn off.) 4. Try removing the RAM modules one at a time and booting up. Could be a bad stick of ram preventing anything from showing. 5. Remove the processor, and boot up without it after clearing the cmos (should be a button on the motherboard, and if not, there are three pins with a little jumper on two of them that will say cmos near them, put the pin on the opposite far pin, and the middle one, then boot without the processor in, wait ten seconds, put everything back the way it was, then reboot. If all that fails, You've got me :S Good Luck
Jan 08, 2011 | EliteGroup 945G-M3 (V1.0b) (945GM310B)...
I have a 848p-A7 motherboard with a intel pentium 4 processor. I just got everything, set up the cpu fan, and etc. but whenever i try to start up the computer, the onboard speaker keeps going off. It's a...
1. Along beep on a motherboard indicates something is connected backward such a a fan or a data cable to the hard drive.
If it is the hard drive cable then you must have pin 1 connector turn around and therefore the mother board is giving a warning.
2. You may have a power supply failure that is the power supply is not giving proper voltage to the mother board.
3. Your ram chip is not properly seated in the RAM slot or in backwards.
4. The CMOS battery to the mother board need to be replaced.
Sep 10, 2010 | EliteGroup 848P-A7 Motherboard
Compaq EVO 510 2.4GZ Motherboard Question
YOU MAY HAVE TO CALL HP /COMPAQ TO SEE IF YOU HAVE THE RIGHT MOTHER BOARD FOR THAT PC
Jan 08, 2010 | Compaq Evo D510 Minitower (Open Box)...
My d530 minitower powers off unexpectedly and red lights starts to blink on System's LED//
Hi Kindly let me know how many times the red light blinks
Condition Code Service Actions Processor thermal protection activated. Power LED blinks red twice, once a second, followed by a two second pause.
  1. Make sure the computer air vents are not blocked and that the cooling fan is running.
  2. Open the hood, press the power button, and see if the processor fan spins. If the fan is not spinning, make sure the fan cable is plugged into the cable header on the system board, and that the fan is properly installed and seated.
  3. If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
  4. Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed. Power LED blinks red three times, once a second, followed by a two second pause.
NOTE: This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly. Power failure (power supply is overloaded) Power LED blinks red four times, once a second, followed by a two second pause.
  1. Check the voltage selector, located on the rear of the power supply, is set to the correct voltage (the correct setting depends on the region).
  2. Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
  3. Check if a device is causing the problem by removing all attached devices (such as disk drives and expansion cards), then power on the system. If the system enters POST, power off and replace one device at a time, repeating the procedure until the system power failure reoccurs. Replace the device that caused the failure, then replace each of the other devices and confirm that they are functioning properly.
  4. If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
  5. Replace the system board.*
Pre-video memory error. Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
  1. Reseat the DIMMs in the memory slots on the system board, then power on the system.
  2. Replace the DIMMs one at a time to isolate the faulty module.
  3. Replace 3rd-party memory with HP memory.
  4. Replace the system board.*
Pre-video graphics error. Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded. For systems with a graphic card:
  1. Reseat the graphics card and then power on the system.
  2. Replace the graphics card.
  3. Replace the system board.*
For systems with integrated (on-board) graphics, replace the system board. PCA (system board) failure. ROM detected failure prior to video. Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded. Replace the system board. Invalid ROM based on bad checksum Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
  1. Reflash the ROM using a ROMPaq diskette.
  2. Replace the system board.*
System does not power on. No beeps or blinks since the system is not functioning. Press and hold the power button for less than four seconds. Perform the following steps depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
  1. Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
  2. Remove the expansion cards one at a time until the 3.3V auxiliary light on the system board turns on. If removing a card turns the light on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
  1. Make sure the computer is plugged into a functioning AC power outlet.
  2. Open the hood and make sure the power button is securely fastened in the power harness and that the harness is connected properly to the power connector on the system board. In other words, make sure that the power button is making contact with the power circuit.
  3. Make sure the power supply cables are connected properly to the power connectors on the system board.
  4. Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
Dec 29, 2009 | HP Compaq d530 Convertible Minitower PC...
The beeping sound of the emachine desktop T3414 makes a long beeping sound for 4 seconds flat and pauses for 2 seconds and repeats the process. Hope this is a broader explanation of the problem. Thanks.
Open cpu cabinet.
Then refix RAM memory.
Pull processor fan and then processor remove dust from all parts and circuit.
Reattach both processor and its fan.
then check if still face same issue.
Then pull cmos cell from motherbord.
Change RAM memory slot module .
Remove pic cards from PCI slot.
Reattch ATX power connector from smps to motherbord.
Then check.
If still face same problem then your RAM has need to be replaced.
Let me know if you need more assistanse.
Thanks.
Sep 19, 2009 | E-Machines eMachines Desktop PC
M2N MB LED is on, fan comes on for 2 seconds only
It's a bad power supply. Couldn't be a bad Power On switch, because it turns on for 2 seconds.
You have to have Ram to get the computer to function, besides the processor. All you will see is the BIOS Setup screen.
Been using the same power supply?
The power supply has bad Electrolytic Capacitors in it. These bad 'Caps' in turn make a weak voltage rail. You have three main voltage rails inside a computer power supply.
The 3.3 volt rail, the 5 volt rail, and the 12 volt rail.
With a weak voltage rail, the processor won't have enough power to run.
ALL the lights, (Lamps), use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
Processors use 55 watts to 125 Watts. Depends on the processor.
Jul 25, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
New asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Aug 23, 2008 | Intel Motherboard
Power supply
angeldram3
as i think ur processor over heated. or processor can dos not work fine or heat sink not installed properly. remove heat sink, and use heat sink component (a whithe colour gel. u can buy it any computer accessories shop) use it top of ur processor then attached heat sink. and connect processor fan. before installing heat sink check processor fan. then cleare CMOS by removeing battery (because this problem also can happen wrong frequency setting in CMOS setting).
Jun 29, 2008 | Gateway Bestec ATX-300-12EB3 305w Power...
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Intel D945GPM Motherboard Logo
90 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
