Question about Coby MP705R Digital Media Player
My mp3 player battery will not charge up. i have plugged it in for hours at a time and it wont charge at all
5 Suggested Answers
SOURCE: coby mpc7095 mp3 player
I have a coby mpc7095. When I try to download music or videos the computer says device not found.
How do i correct this problem
Posted on Apr 10, 2008
SOURCE: Trouble charging the #MP-C7052 Coby MP3 Player
I dicovered you had to shove the charger into the port with a lot more force than most electronics. When I did this it charged in about 15 minutes.
Posted on Oct 02, 2008
YourZEN
  • 820 Answers
SOURCE: How do I recharge Coby MP3 player? I plugged into
Coby MPC7085 requires a 12 hours charge when used for the first time.
Always use a direct connection to the computer when charging with the USB cable: a hub or cardreader should be self-powered.
See page 12 of the manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Posted on Sep 28, 2009
Testimonial: "This was very good info. Thanks."
  • 13 Answers
SOURCE: Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Posted on Apr 10, 2010
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
Battery wont charge
I would say leave it stay on then after its fully dead charge it up again . That should fix your problem if it doesn't leave a comment and ill try to help again.
Jan 09, 2010 | GPX Audio Players & Recorders
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
My fully charged MP3 player wont stay on. It
Yeap , time to replace the battery. after a certain amount of used hours all MP3 players will start to do this until it no longer has power.
Jun 03, 2009 | Audio Players & Recorders
Zen wont work on battery
The battery is bad or the charging circuit is flaking out. Try plugging it in and from the wall side of the charger, unplug and plug it in several times. Sometimes on the Zen players that will shock it back into charging. I have seen that same charging issue on several models of Creative players.
Cheers
Jan 04, 2009 | Creative Labs ZEN Vision:M Digital Media...
Mine wont turn on
On the back of the the mp3 player is a reset switch.
Hold that down about 15 seconds.
If that does not work go to the RCA website.
Download the latest firmware.
Plug mp3 player into pc.
Install the new firmware.
Keep it plug to computer for about 1 hour to charge the battery alittle.
Dec 27, 2008 | RCA M4204 MP3 Player
Nextar MA715 MP3 player wont take a charge.
Best first bet is dead battery. If it is a special battery then do the costings for the repair as it may be cheaper to replace the player.
Jun 13, 2017 | Nextar MA7151B MP3 Player
Help..
Just leave it until the battery runs out and it turns off by itself. Then plug it in and charge it. Once it's charged, turn it off. Then wait at least an hour before turning it back on.
Oct 17, 2008 | Coby MP-705 Digital Media Player
Do i have to let the mp3 player charge for 3 hours before i get started
sorta the recomended time before you use it is so that the battery can expand if u charge it 4 i hour first time u use it it wont open the baattery that much and it will die so quick in future
Sep 29, 2008 | Audio Players & Recorders
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Coby MP705R Digital Media Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Peter Dragonetti
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
