Question about Kenwood eXcelon KDC-X869 CD Player
It lights up but doesn't come on completely - Kenwood eXcelon KDC-X869 CD Player
  • 35 Answers
Try checking two different items.
  • First, using a multimeter or test light ensure that there is correct voltage going to each of the sources and you have a good solid grounding source.
  • Second is trying a reset to the unit.
Posted on Nov 11, 2010
Light doesn't work
First check the lamp; make sure it isn't loose in the holder,check the filament is still complete. Next check the light switch has power and is closing with the door opening. If no power, check wiring/ connection. If power in and out can only be the lamp!
Jun 11, 2012 | Frigidaire Freezers
Esp light showing on my dash board
Try the reset procedure, With the car running out of gear turn the steering wheel completely to the left then completely to the right then back to the middle, if this doesn't help or it comes back you will need to get the car checked by a garage with the star diagnostic system to find the issue.
Mar 08, 2012 | Mercedes-Benz Cars & Trucks
Lights dim when rpm increased
Voltage issue. With the bike running, remove the negative terminal off of the battery. If the bike stops, it's the alternator. If it doesn't, have the battery tested. Possibly dead cells in the battery. If that still doesn't work, let me know the model year and we can go from there...
Sep 09, 2011 | Yamaha XPeed 50R Motorcycles
Ommy st503sm stopped firing however put in a new battery but there is now no power to starter and neutral light doesn,t come on now even tho it,s not in gear all lights work
chec connects make sure theyr clean and tite-specialy batt--inspect for loose grounds--may need to test complete ignition-relays/switches/points
Aug 12, 2011 | 2008 Skyteam ST50
I have Toshiba Satellite 2455-S305 notebook. The notebook doesn't start. Power light flashes orange with constant interval about 1 sec. Display remains black. When I remove all memory modules power...
The problem you are having is most likely from having a bad battery. Simply replacing it could fix your problem. It could also be due to a bad power cable that is not giving the correct voltage. Here is a link to the user manuel that explains this and any thing else you may want to know: User Manuel
I hope that this helps you!
HelpDeskMan
May 22, 2011 | Toshiba (P000369080) Motherboard
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
To Enable or Disable the Cycle Completion Signal...
1. Open the door, hold down the “Quick Wash”
button and simultaneously turn the Dishwasher on.
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it
doesn’t beep, it means that the Cycle
Completion Signal has been disabled.
3. Turn the Dishwasher off to take it out of
program mode.
I hope this answer's your question. Thank you for choosing "fixya".
Please rate the solution favorably if indeed it was helpful, if not please let me know.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
Kenwood eXcelon KDC-X869 CD Player Logo
62 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
