Question about Kenmore Dryers
It works but it doesn't heat the air - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
NEW REMOTE WILL NOT WORK IN HEAT MODE
maybe the new remote doesn-t have in operation mode the heat.
Dec 27, 2013 | Haier Heating & Cooling
Heat doesn't work
You mean the air coming out of the vents is not hot, or there is no air coming out ?
No air could be a blower or a blend door, and no hot air could be a blend door or something with the heater core like low coolant in the radiator.
Sep 20, 2012 | 2004 Dodge Ram 1500
JEEP CHEROKEE LE DRIVER SIDE HEAT DOESN'T WORK
If you have heat on the passenger side then this is just a simple case of the hose supplying the heat has com off of the heat exchanger
Aug 26, 2012 | 2001 Jeep Grand Cherokee
Heat stays on even when temp is cool and compressor doesn't work
Have a professional diagnose the communication between the main control board, and the timer.
Aug 14, 2012 | Frigidaire FAH125P2T Air Conditioner
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
Blower on heat/a not working
So it works with a/c but doesn/t work with heat. Is that what your saying?
Or it blows cold air on heat selection?
If it blows but only blows cold air on heat selection
check out the following items:
temperature selector switch
blend door actuator and motor.
Here are a list of items to check out or have a shop inspect if it doesn't blow anything at all.
a) on/off switch
b) relay
c wiring
d) resistors
e) blower motor
May 11, 2010 | 2004 Chevrolet Colorado
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
