Question about Ranger Pickups 19932010 Books
My parking brake light stays on even when releasing the parking brake handle.
    Genius:
  • 1,672 Answers
Check your BRAKE switch under the steering column, just where ur brake pedal resting on it when ur not stepping on it! Connection might have been disconnected or the switch needs replacement! Taah!
Posted on Nov 11, 2010
Testimonial: "That took care of it. Thank you. "
2009 Grand Caravan the parking brake light stays on after the parking brake is disengaged?
sounds like the parking brake arm is not returning to the fully off position. try pull the release handle and at the same time pull up on the lever. if the light goes out then its not fully returning. it could be out of adjustment or the brake cables or sticking and need to be freed up.
Mar 10, 2015 | 2009 Dodge Grand Caravan
When the parking brake is unset the warning light stays on how do i get it off its on my 2000 explorer
Try pulling release handle and pulling up on the e-brake pedal.then afterwards adjust parking brake.
Sep 11, 2012 | 2000 Ford Explorer
Parking brake light won't go off after releasing brake lever
Park brake lights normally operate by a small plunger type switch the turns off when the level or pedal is placed in the off position. Over time the spring in the lever weakens and placing the lever in the off position no longer depresses the switch. The switch can sometimes be adjusted to make better contact, or the switch bracket can be bent so the lever and switch make proper contact.
Feb 17, 2012 | 1992 Toyota Pickup
Brake light stays on after releasing parking brake pedal feels a little soft
Check the parking brake cable to make sure it is moving freely and allowing the brakes to completely release when you pull the release lever. Sometimes dirt and rust will lock the cable. In this case, the parking brake pedal will still sit on the switch even though it is unlocked because the spring can't pull it and the cable back to the off position.
May 19, 2011 | GMC Jimmy Cars & Trucks
Parking Brake Indicator Light stays on. My 1988...
pull the breck release and kick it at the same time same thing i had to do hey it worked for me
May 21, 2010 | 1988 Pontiac Bonneville
Have an Chevy 2000 S10 with parking brake issues.
Get under the veh and check out ,the rusted parking brake cables
Feb 19, 2010 | Chevrolet S 10 Cars & Trucks
Parking brake light is stuck on after releasing the brake handle. Is there a tension adjustment for the cable somewhere that can be tightened up?
of course there is. but befor you go near that...check your brake fluid. when brake fluid is low, that will cause the parking brake light to stay on.
Dec 19, 2009 | 1996 Toyota Avalon
Parkling Brake Console Light Stays On
Parking Brake Console Light Stays On The light is on because the brake fluid is low. The sensor in the brake fluid reservoir is signaling low fluid. This may be because leaking or the brake pads/shoes are worn down, so check to see if they needs replacement. In the mean time you can add brake fluid.
The Parking brake switch is activated by the brake handle. If you use a flashlight you may be able to see it next to the handle.
May 31, 2009 | 2000 Jeep Grand Cherokee
Parking brake cables on '99 GMC Sierra
The cable splits under the cab. One side to the right rear-one side to the left. There is an adjustment under there as well to take up any slack.
Have you repalces your rear brake shoes? As they wear out, your parking brake cable wll become slack. You need to see how much pad you have left.
May 29, 2009 | 1999 GMC Sierra
Ranger Pickups 19932010 Books Logo
373 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
