I am being told that I am not fully protected
    Guru:
  • 1,463 Answers
Hello blairann
is your security programes upto date anti virues etc.
which are you running ?
open each one at a time and check for updates and download any updates needed .
riz.
Posted on Jun 17, 2008
Why has my memory card in my Nikon L310 just suddenly told me that it is "write protected"?
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 26, 2012 | Nikon Cameras
Tip
How to charge your laptop battery properly? During the the process of notebook...
How to charge your laptop battery properly? solarroll-laptop-solar-charger.jpg During the the process of notebook using, we need no to deliberately charge the laptop battery to 100% state or fully discharged laptop battery to automatic shutdown protecting. The correct way is that charge the battery in 20% state and stop charging in 98% . If the machine has the power calibration procedure, when the battery standard-by time significantly reduced. Then calibrate the battery in time to active the protection circuit performance.
For early notebook batteries (Ni-MH Ni-MH or Ni-Cd Ni-Cd), really need to fully charge and discharge in order to maintain good battery capacity. But for the lithium battery is not necessary even it may damage the battery.
In fact the lithium batteries has a little memory effect. The lithium battery materials is very sensitive to the conditions as temperature, the use of frequency and so on. The battery will be aging after used for some period time (standby time reduced). The natural wear and tear is an important reason, and inadequate maintenance is another important reason.
A well-designed lithium batteries have a very good protection circuit to prevent excessive charge and discharge.As over-charging and discharging of the Sony VGP-BPS8 battery will be the rapid reduction activity. Under the protection of protection circuit, the user fully charge and discharge the battery several times, in fact, impossible to achieve had "full" level.
Sometimes WINDOWS show that battery capacity is 20% or more, you can use 30 minutes. But after used 10 minutes or less the machine suddenly automatically shut down. The reason is that the battery has been aging, the battery protection circuit can not monitors the battery real capacity. In the normal battery depletion, the protection circuit original parameters have been unable to properly reflect the actual situation of the battery
So power calibration procedure is to correct the benchmark protection circuit parameters to accurately reflect the actual capacity . This correction process will often take two or three complete charge and discharge. As previously mentioned, fully charge and discharge will reduce the battery activity. It is not frequently used, usually once a month.
on Jan 18, 2010 | Computers & Internet
Turned on camera (Canon PowerShot SD1100 IS) and was told that the card was locked! How did this happen and how can I unlock it?
Take the memory card out of the camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 14, 2010 | Canon PowerShot SD1100 IS Digital Camera
I was able to retrieve the pictures off the memory card but can't delete them. I tried putting the SD card in my Canon Digital Elph, same deal. I thought a reformat of the card in the camera would...
There's a tab on the side of the SD-card which sometimes slides to lock(=write protect) position when you enter the card in the reader/camera. Can you take photo's? Are you sure the tab is on 'write enable'?
Oct 29, 2010 | Cameras
Ive just bought my camera, ive installed it etc, when i take a picture " card protected " shows, and therefore no pictures save, helpp!!
You didn't specify what make and model camera you have, so I'm going to assume it uses SD and/or SDHC cards.
Oct 16, 2010 | Cameras
Ck. air suspention light came on and car lowered and drove rough. I took the car in for analysis and mechanic told me it needed a fuse that cost $22. I did not have the fuse replaced but went to the auto...
That is what a fuse does: it protects the electrical system from catching on fire. If the new fuse you installed didn't burn out right away, you are okay. The mechanic was just playing it really safe. If you did have a really bad short the new fuse would have blown right when you installed it.
Jan 23, 2010 | 1996 Mercury Grand Marquis
Memory chip is protected
use a different memory chip. the chip you got was password protected
Dec 31, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Roxio cd upgrade
Sir,
The roxio software is difficult to use. That software have use only original buyer will get upgrade.ok. So that software is fully copy protected so only authorised buyer can use of it without any problem. U just reinstall the OS. This would make better. ok
Thanks
Good luck
Don't forget to rate the solution.
Jun 29, 2008 | Roxio Computers & Internet
Disabling Bios Writing Protection
Sometimes the BIOS calls this protection some sort of "virus protection" as past viruses, like the CIH virus would tend to overwrite motherboard BIOS' with jargon, bricking the motherboard. Try disabling any onboard "virus" protection and try flashing your BIOS again.
Sep 07, 2007 | Soltek SL-75FRV Motherboard
Computers & Internet Logo
19 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
