Question about Bryant /murray Bj2200 Main Circuit Breaker 200amp
Where is the main switch to shut off the power in the house? I was vacuuming and the power went out in various areas around my condo. I think I have isolated the breaker and want to change it but I do not see the main power switch to shut off all the power. Is it behind the panel?
  • 760 Answers
In some condos/apartments the main breakers are located outside. This is because the meter and incoming service are some distance from the local panel. Perhaps your breaker isn't bad, but the additional load of the vacuum caused it to "trip" Unlike some brands the Bryant don't show a trip indication other than the handle moving. Try turning this breaker completely off, ( if it was tripped, it will click) then turn it back on. If you do locate the main outside, and decide to change the breaker inside, be sure to "lock out" the main disconnect while you're working on the panel.
Posted on Nov 15, 2010
GE Spacemaker dryer PCKS443FBWW. Dryer shuts off mid cycle and will not start again until 10 minutes or so go by
Go to www.repairclinic.com and enter PCKS443FBWW. You will be presented with a list of common replacement parts and may be able to view a generic GE video showing disassembly and identifying various parts. Do some preliminary checking to determine whether something got disturbed during the vigorous cleaning.
Nov 11, 2016 | GE Dryers
Any ideas on why my vacuum cleaner would quit working?
the on off switch perhaps .then the motor itself
May 12, 2015 | Vacuums
Replaced timer on dryer because would not shut off sometimes. dryer was working while I had it open I was vacuuming out lint around drum and switches. had door open and light was on suddenly light went out...
if its on a circuit breaker,just switch the breaker off,then back on,they can drop out ,but still show good
if this is not the case,check the incoming power block inside the dryer as a burned off neutral conductor can result in the same condition
Sep 11, 2011 | Dryers
I was using my Heritage 11 vacumn with the hose attachment and the motor shut down like the power went off .When you push the switch on the housing the light comes on but the motor does not run.
Hi, the motor could be overheating. Most vacuums have a heat sensor that shuts the vac. off if there is a clog. Let it sit, feel if it's hot. If so you may have a blockage of dirt etc. Try to clear it, let it cool and tart it up. I hope this helps, if not let me know with more details and we can narrow things down Chris
Feb 09, 2011 | Kirby Heritage II Vacuum
Heat pump stops working in cold weather
Sounds like there is a problem with your unit. The cooling tower doesn't have anything to do with the compressor other that the delivery of water to your heat pump. The compressor is probably shutting off on a low pressure because the water is cooler than in summer. I think the heat pump you have is low on charge or has a defunct TXV.
Jan 11, 2010 | Weather King 12AJA4801AH Air Conditioner
I need a wiring diagram & detailed specifications for my Filter Queen Majestic limited edition.
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Sep 07, 2009 | Filter Queen Majestic Canister Vacuum
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
No heat through vents
Does your condo have more than one thermostat? if so there are powered dampers that open and close to direct heat where it's being called for. You may have dampers stuck/inoperative.
Mar 22, 2009 | Omega Trane Furnace Draft Inducer Blower ...
Dyson DC07 main power switch
you will need to replace this switch remove the bucket from the front of the machine and the handle and pipe from the back on the front of the switch housing you will see a screw remove this screw on the back you will find two little catches one on either side push these with a screwdriver then the sides of the switch housing will pop out from the chassis now on the front theres another on the bottom of the housing push this down and pull the housing off from the front when replacing this part be carefull not to trap any wiring
Oct 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I got a sony trinitron over the last few months it takes a long time to switch on,sometimes up to 2 mins!. was wondering if you know wots wrong? thanks
I would think that this TV has some colder solder joints around the high voltage area and the power supply as well. Check mainly the high power resistors area.
Jan 17, 2008 | Televison & Video
Bryant /murray Bj2200 Main Circuit Breaker 200amp Logo
268 people viewed this question
Top Bryant Electrical Supplies Experts
john h
Gene Haynes
Tom Chichester
Are you a Bryant Electrical Supply Expert? Answer questions, earn points and help others
