Question about Motorola Mobility Tundra VA76r Cell Phone
My Motorola Tundra flip hinge won't keep the phone closed. It is loose at partial open. When I try to answer or pick it up, it hangs up on the incomming call. How to fix? Bryan
My Motorola Tundra won't send or receive texts. It won't even go into the message or voicemail section. If you keep trying, it will shut down and restart. Everything else works okay.
My Tundra did the same thing I fixed it, give this a try, main menu-settings- phone settings- Reset-Reset all data (code is 6 zeros...example 000000) then , delete All data(code 000000), hope it works for you!
Nov 29, 2012 | Motorola Mobility Tundra VA76r Cell Phone
How do I get my motorola gleam phone to answer by opening the flip
To Enable Answer/End Call by flipping open / close the lid you have to enable it in the phone menus. Surprisingly it's not in settings ( where it used to be on older Motorola phones).
Key presses:
  • Menu
  • Select Call center(top left)
  • Call settings (2)
  • Advanced Settings (5)
  • Answer mode (7)
  • Select Cover Answer
Done
Jun 25, 2012 | Cell Phones
LG vx8350r hinge is broken on right side. Should I look for repair parts or a replacement phone? My wife like a simple phone and would keep this model if I can get it fixed
My VX8350 broke on the right side too. Actually it cracked and the pieces, 2 if I remember correctly, kind of were just hanging there (in other words I did not loose any pieces of plastic). I did a very careful repair and it has held now for about 1.5 years with no problems and I've even dropped the phone about 4 times or more since the repair.
I used the CA glue, (cyanoacrylate glue or some know it as instant glue). But be careful so you do not glue your hands to the phone. Use VERY LITTLE glue cause it WILL wick into places you do not want it to go. Lastly, you have to index the metal piece in the hinge (use a hefty pair of tweezers) before gluing so the spring with work correctly and hold the phone either open or closed. If you error on the indexing, try to error on the side which will keep your phone tightly closed when closed and just barely short of fully open when open. That way you won't be catching the closed phone on things with it hanging partially open. It doesn' t cause any problems being just a tiny bit short of fully open.
So, open the phone, carefully tilt the two halves to expose the metal hinge, index the hinge, carefully rotate the two halves back to their proper position and carefully test the opening and closing action. If it's good, or good enough, then put the chunk(s) that broke loose back into position and while holding everything in place put a TINY bit of CA on one of the cracks. This should setup very quickly (hence the name instant glue) and if you can still remove your finger from the phone, do so, and put a tiny bit of CA on any other areas or other cracks where the glue did not wick to. Remember to use very little glue for this or you'll be sorry and your phone won't work. If you did this properly, your phone will now open and close like it did before...or very close to it. Good luck.
Aug 16, 2011 | LG VX8350 Cellular Phone
I HAVE CHANGED BROKEN FLAP 2 MONTHS AGO BUT THE FUNCTION OF OPERATE SYSTEM AFTER CLOSE THE FLAP CANT WORK PROPERLY, SO PLEASE TELL ME WHAT CAN I DO?
Was the flap changed by a techician ?
I have played with my 1200 and thus
know the flap hinge area has two special aspects :
(a) embedded-into-hinge-on-one-side, a spring loaded mechanism, for the firm open-close action.
(b) a small circular magnet embedded within the hinge framework (this magnet working from the right location should be essential to trigger the answer-when-flip-open or disconnect-when-flip-is-closed systems).
So your problem could be due to one or both of these things not being (re)installed correctly.
Good Luck.
fixya[at]technife[dot]com
Nov 05, 2010 | Motorola Mobility A1200
MOTOROLA KRZR K1 SCREEN GOT BLANK (WHITE OR BLACK)
I believe you have a problem with the hinge of the flip where your wire that connects to the display opens up your screen. If you keep opening the flip and closing it slowly does the screen turn on and off??? If it does then you have a problem with the hinge like I said. If not then it could be just a software glitch where you need to reinstall the operating system.
Sep 24, 2017 | Motorola Mobility MOTOKRZR K1 Cellular...
Loose hinge spring on flip
programa de motorola phone
Jul 01, 2008 | Motorola Mobility RAZR V3
Motorola V3 - Loose top flip
the phone need to be open and fixed
Feb 11, 2008 | Motorola Mobility RAZR V3
V3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Hanging up
It should be consistent in both directions, you might try backing up your phone directory and doing a master reset.
Oct 16, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility Tundra VA76r Cell Phone Logo
998 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
