Question about Frigidaire FGX831CS Top Load Stacked Washer / Dryer
Fridgidaire fgx831cs won't drain or spin. It makes a horrible noise but will not spin
  • jworthyco Nov 11, 2010
    It looks like the part for the transmission is around $275. Are there going to be a lot of other parts needed as well?
    Thanks
  • 1,531 Answers
Remove the front panel by pushing in the two clips on the front end of the machine and removeing the two screws on the bottom.then put the unit in a drain and spin mode and see what happens you may need to remove the hoses from the drain pump and look for any obstructions.you can also grab the inside of the tub and try to move it.It should only spin in one direction if it moves in both directions then the transmission is bad.
Posted on Nov 13, 2010
  • 10,865 Answers
Hello. I am sorry to be the messenger of this but your transmission is shot. That said, the repair is costly even if u do it yourself. If the machine is more than 3 years old I recommend that u put the money toward a replacement rather than a repair. Joe
Posted on Nov 11, 2010
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
Grinding noise in spin cycle
It sounds like the drain pump needs replacing, its bearings have failed or there is something from the wash jammed in it. But before you buy a new one, get the machine checked by an expert in case lots of parts are damaged.
Dec 20, 2013 | Whirlpool Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Washer is making a horrible sound while draining water from tub
if horrible sound is while drainpump is draining but before washer starts to spin either obstruction in drain pump or impellar on pump is bad and the complete pump needs replaced... if noise is while spinning the spider support is cracked which is very exstensive repair and dont reccomend repairing unless you have a couple of hours for dissasembley and reassembley...
Jan 24, 2011 | Samsung WF337AA Front Load Washer
While washing it makes a horrible "grinding?" noise and after draining the clothes are still wet and it will not spin. the horrible noise is on during all cycles. will not spin. HELP, please!!
Sound very much like something (coin etc) is stuck in the pump, have had a look online to see if I can find a diagram to check if there is a customer access filter for you to check. Unfortunately, I can't find one so if you have your owners manual see if there is any info. This will also be the answer to the spin problem as most w/m will not spin until all water has been expelled. Hope this helps.
Jul 07, 2010 | Kenmore 24032\24036 Top Load Washer
Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
May 18, 2009 | Kenmore 22422 Top Load Washer
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FGX831CS Top Load Stacked Washer / Dryer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
