Question about HP Pavilion DV9920US Laptop
My screen went bad and i have tried the invertor and other things, no one can tell me the problem.
  • 2,567 Answers
Please follow the diagnosis outlined in this article to check whether the backlight lamp or the inverter board are the root cause of the problem or not:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine.
Posted on Nov 11, 2010
Dell inspiron 1545 dim screen suddenly
sounds like backlights are gone, needs new invertor or screen, 90% of the time its just the invertor there like 9 pounds on ebay atm, and aint that difficult to fit,
Jun 19, 2012 | Dell Inspiron 1545 Notebook
Powers on screen went black. Tell me what I can do to fix it ? Just some knowledge would be greatly appreciated on this issue. After that I can manage from there, Thank you
This is a common issue with flat screen TV's.
Try changing the input on your television or changing a channel. If the screen remains black, it is either your internal power supply, LCD invertor, or backlight.
A television repair shop should be able to fix this OR you may just have to get a new tv.
May 04, 2011 | Televison & Video
Dv4000 screen is on for a few seconds then goes black. Replaced screen balast and worked for 10 minutes, then went black again as before replacement. Should I replace the lcd screen?
No. The bulb is good. It could be the DC/DC invertor - that little curcuit board just beneath the in the LCD - or the video off the notebooks motherboard. - personal experiance points to that invertor
Feb 25, 2011 | HP Pavilion dv4000 Notebook
I first broke the screen on this laptop i changed it but shorted out the invertor at this point the laptop switched on fine with a dark screen after replacing the invertor with a new one it no longer turns...
You should have checked the power voltage rating before using another power cable.
The computer memory or processor must have gone bad.
Check the power rating before connecting another inverter.
Dec 24, 2009 | eMachines eMD620-5133 Notebook
HP L1720 flickering!
this is common, the display is bad.
all displays, fail. all do. no reason to get angry,
a broken display is worth nearly zero value $0
so how much money will you spend on worthless.?
you can get a new display at Walmart for $65, ,
lines are usually very serious. and is not ever the DC-DC inverter
a bad inverter (< it's power supply) is for the back ground lamps. not data side. the data side is failing and is common, if you twist the screen
it gets worse. ? bingo. data driver connections bad , screen.
IN most cases the part that is bad (screen), costs $100 new. or 50 used
why go there/
Jun 01, 2017 | HP L1720 17 in. Flat Panel LCD Monitor
Why does it take 10 minutes for my LCD Legend tv
Sounds like you have a faulty capacitor on your invertor..Gently press on the screen when there is no picture.is there light on the screen? If so, there is backlight but no video..hence a mainboard or power supply problem..If there is no backlight then the problem is the invertors or the power supply not supplying 24volts. The invertor is located on left or right hand side of screen..Check that all connections are secured and not loose.Check that the power supply capacitor tops on the power supply do not have bulging tops..If not, and voltage is reaching the invertor, then remove the invertor and check for bad solder joints and leaking capacitors.
Oct 17, 2009 | Televison & Video
My screen on my Dell Inspiron Notebook went black. But I can barely see on the screen that the computer ran a problem check and said my computer was having a problem starting.
The invertor lamp has gone bad, so you would need to replace the LCD screen. there is nothing else you can do. try to connect an external monitor adn then press Fn + F8 to switch the video to the external monitor. if the image on the external monitor is fine then its the lcd. if the external monitor has the same image then motherboard problem. you can also try Fn + Up arrow key to increase the brightness.
Oct 16, 2009 | Dell Inspiron 1000 Notebook
We have a sharp aquos. We have audio, but no screen image and i can't firgure out how to restore the TV image
Is this through the tuner or input? If its through input check or switch out cables first. When you have sound if you can shine a flashlight into the screen and see movement or video, your backlight is out, which can be a invertor board or bad capacitors on the power supply board. Invertors have to be replaced, some power supplies can be repaired. A repair shop will be able to tell which it is.
Sep 06, 2009 | Sharp Televison & Video
Acer travelmate 4500 screen problem
if u have two memmory stick.try to boot with one..if it not ok try it with other one...
Nov 30, 2007 | Acer TravelMate 2300 Notebook
D600 screen went very dim
You also might check to see if there is a HOTKEY setting for the brightness of the screen (usually FUNCTION or FN and then some key on the top row).
Replacing the backlight on an LCD is a very advanced and trouble prone procedure, unless you are good with soldering and taking things apart, you should probably use it with an external monitor or think about getting a new machine. :>|
Oct 26, 2007 | Dell Latitude D600 Notebook
HP Pavilion DV9920US Laptop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
