Question about Belkin (F5D7132) 802.11b/g Wireless Access Point
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
  • 6 more comments
  • Anonymous Jul 04, 2008
    I am having the same issue
  • eonsure Aug 02, 2008
    And me! It also fails when run in XP compatibility mode.
  • Anonymous Sep 02, 2008
  • Anonymous Oct 20, 2008
    same prolem
  • Anonymous Oct 21, 2008
    Same Problem!
  • majdi944 Dec 18, 2008
    I have the same problem, and the above solution did not solve the problem.
    majdi944@hotmail.com
  • Anonymous Jan 05, 2009
    the same problem..
  • peage Mar 17, 2009
    i have the same problem
Posted on Sep 16, 2008
    Sergeant:
    Champion:
  • 236 Answers
Have you tried installing it as "administrator'?
Posted on Aug 07, 2008
Right click on the icon and click "Run As Administrator" this works for Vista
Posted on Nov 20, 2008
Why can't I install download of Magix Movie Edit Pro 14 in Windows 7
You try try the compatibility wizard in Windows 7 to see if you can install Magix Move Edit Pro 14 in compatibility mode for Windows Vista.
To run the Program Compatibility troubleshooter
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
Feb 27, 2014 | Computers & Internet
I have windows 7 on my machine and can't get the driver IP802MR.exe for my Belkin range extender to work. I have changed the properties to xp with administrator rights....no luck
You have to download and install the driver for windows 7 ..To do that you should access the support site of the manufacturer..If they have no driver for it ..it means the device is not compatible with windows7 or the driver was not issued yet ..(In this case try the driver for Vista ..should work OK )
http://www.belkin.com/support/
Aug 28, 2011 | Belkin (F5D7132) 802.11b/g Wireless Access...
How can i turn off the compatibility mode of my itunes
First u need close the itunes.
1: Windows XP and Windows 2000: On the Start menu, click My Computer (or double-click My Computer on the Desktop).
2: Windows Vista and Windows 7: On the Start menu, click Computer.
3. In My Computer, open the C:\ drive (or whichever disk your Windows is installed on). Open the Program Files folder or "Program Files (x86)" if you are using a 64-bit version of Windows Vista or Windows 7).
4. Open the iTunes folder.
5. Right-click on the iTunes application (iTunes or iTunes.exe) and from the shortcut menu, click Properties.
6. Click the Compatibility tab.
7. Deselect the checkbox under Compatibility mode if it's selected.
8. Click OK.
9. Open iTunes and play a song.
This should take care of the problem.
Jun 23, 2010 | HP Pavilion dv6000z Notebook
Any way to get the cd for the sony PEG T615C to install on computer with vista OS?
Hello.
From FixYa Support:
Run the program in XP compatibility mode.
First install the Palm Desktop CD that came with the CLIE. Go to "Start"> All Programs> Sony Handheld
1. Right click "HotSync Manager" and click "Properties" click Compatibility tab and and check "Run this program in compatibility mode for: Windows XP (Service Pack 2).
2. Then HotSync your CLIE it should work.
If it doesn't work:
1. While installing software from the CD open the CD and Right-click setup.exe and check XP Compatibility, and while installing, if a pop-up appears for drivers, just Click Use Old Drivers anyway.
2. In "Start"> All Programs> Sony Handheld
Rightclick all the shortcuts like "Palm desktop for Clie", "Install tool", "Hotsync manager" and set it to run in XP compatibility mode.
Hope this helps.
Jan 12, 2010 | Sony CLIE PEG-T615C Handheld
Cant get my belkin network adapter to work on windows 7 because it says there are no drivers installed for this device
This Will work in most Cases
Download the Drivers for Vista 64 Bit from
Step 1 : Right Click on the EXE File and Click properties
Step 2 : Click on the Compatibility tab
Step 3 : Select run this program in compatibility mode for Windows Vista SP1
Step 4 : Click Apply
Now try installing the Drivers
Dec 26, 2009 | Belkin High-Speed Mode Wireless G Notebook...
Belkin n adaptor will not work with windows 7
Download the Drivers For Vista2_bing.gif 64 Bit From
Step 1 : Right Click on the exe File And select Properties
Step 2 : Click The Compatibility Tab
Step 3 : Select Run this Program in compatibity mode For Win Vista SP12_bing.gif
Step 5 : Now try to install it
Nov 08, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Vista driver for Intel QX3 Microscope
Instruction for installing the QX3 or QX3+ Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
Is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Feb 14, 2008 | Intuit QuickBooks Pro 2003 Single User...
Vista will not recognize my Clie
Please install thePalm Desktop Operating System 6.0 or higher from any search engine or Palmzone.
This will resolve the issue.
Regards
Chris 2030
Jan 12, 2008 | Sony CLIE PEG-T615C Handheld
Installing this PDA on Windows Vista Home Premium laptop
you shouldnt need a device driver for your pda to work along side with Vista, as Vista has it's own Windows mobile device centre which should run as soon as you connect your pda to a usb port. If it doesnt run, then open up windows mobile device centre in programmes and check the mobile device settings as to whether usb is set to connect to the centre.
Jul 03, 2007 | Sony CLIE PEG-T615C Handheld
Belkin (F5D7132) 802.11b/g Wireless Access Point Logo
3,694 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
