Question about Crane Frog EE-3191 1 Gallon Humidifier
The nightlight doesn't seem to work. We took the humidifer out of the box and used it for the first time. The nightlight button seems like it is pushed in already--perhaps jammed? It does not turn on.
Someone called Crane company to find out that there is NO night light. The frog design just doesnt have one. They said that the manual is a generic one for all the humidifiers.
Posted on Jan 04, 2011
Aprilaire 560 not keeping contant power to cause humid. to work
You may be havig problemm w/ the current sensing relay, try bupassing the current relay and see if the hum. comes on and if it comes on the try rapping the wite wire from the main blower 2 times. hope that helps
Feb 02, 2009 | Aprilaire 550 Humidifier
Too much water running through to humidifier
With the Honeywell he220, you will use alot of water, trying to turn down the water will only reduce your amount of humidity in the home, you may be able to adjust it a little but you need to take the cover off and reduce the water flow a little at a time watching the water as it flows across the pad, you just have to make sure the humidifier pad is getting plenty of water across it, to little and you lose your humidification, hope that was helpful to ya, thanks for your question,
mr.grzz
Jan 25, 2009 | Honeywell HE220A1019 Whole House...
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Not enough humidity
seems to me you have a calcium build up inside the unit, something has slowed down the humidification process and that would be the most likely cause, you should run some diluted (CLR) through it and this should take care of the build up, leave it set for a while with the diluted solution in it then drain it out, and refill, give that a try and it should help, also check to make sure the fan is not getting cloged with dust and clean that too, thanks again for your question, please let us know how we did,
mr.grzz
Jan 22, 2009 | Bemis 427 300 Humidifier
Not working correctly
Does your humidifier use an ultrasonic transducer for vaporizing the water?
May 08, 2017 | Crane Penguin 1 Gallon Humidifier
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
HE120 By-pass humidifer - Sponge Drum not rotating!!
Model HE908A drum is turning but we get no condensation
Dec 25, 2007 | Honeywell HE120 Humidifier
Water not running through humidifer
Mine had the same problem no water through the solenoid. It turned out to be the little adapter with the needle hole on it, attached to the solenoid on the intake side. It was clogged, cleaned it out and works great now.
Nov 18, 2007 | Honeywell HE220A1019 Whole House...
It could be a problem with the water level sensor. It may have gotten stuck, and is unable to correctly sense the amount of water. I just posted the instructions from the manual here.
Nov 05, 2007 | Crane Penguin 1 Gallon Humidifier
ER3 Message
We had this problem and could not make it go away by refilling, jiggling the float and so on. All the controls appeared frozen during this time.
But unplugging the humidifier for 5 minutes and plugging it back in seems to have fixed it -- no ER3 message now (fingers crossed!0.
Apr 25, 2007 | Slant Fin Warm Mist GF-210 Humidifier
Crane Frog EE-3191 1 Gallon Humidifier Logo
103 people viewed this question
Top Crane Humidifiers Experts
bigdaddyd2
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
