Question about Toshiba 32HLC56 32 in. HD-Ready LCD Television
Display Flashes After 30 minutes the display starts flashing no matter what the input source is. Took to factory authorized repair shop. They said the ballast on the inverter board is the problem. The LCD panel would have to be replace at a cost of $1400.00 ????? I purchased this HDTV from Best Buy for $700.00 in Dec. 2006. It has been out of warranty for only 6 mo. What gives! Is the repair shop just blowing smoke or is this for real?
  • 2,326 Answers
I wouldno't say the LCD needs to be replace. If the repair shop said that the inverter board is the problem, it could be but the way the LCD is behaving; i would suspect the power supply might not be providing the proper voltage to the inverter board circuitry making the LCD flash after it warms up.
Let me know if you need further assistance.
Posted on Jun 17, 2008
Screen will not display any picture despite menu and tuner working?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 16, 2016 | Televison & Video
Tip
How to configure 'Video 1' input to use Digital Optical connection
Connect the optical cable to the DIGITAL OPT(ical) IN connection.
Press the purple 'VIDEO' button on the remote until 'VIDEO 1' appears on the display.
Press the SYSTEM MENU button (to the right of the DVD play, pause, stop buttons).
'VIDEO1 INPUT' flashes on display.
Press ENTER
'INPUT ANALOG?' (the default) flashes on display.
Press right arrow (to right of ENTER)
'INPUT OPTICAL?' flashes on display.
Press ENTER
'INPUT OPTICAL' displays briefly, then
'VIDEO1 OPT' displays.
You are done. Selecting VIDEO 1 in future displays 'VIDEO1 OPT' instead of 'VIDEO 1'.
on Mar 02, 2014 | Pioneer NS-DV88 System
HOW DO I SET MONTH DAY AND TIME WITH BP3MW1-1W 800229
Below are the Date and Time setting instructions for a similar model: OMRON BP742
http://omronhealthcare.com/products/5-series-upper-arm-blood-pressure-monitor-bp742/
Set the monitor to the current date and time before taking a measurement for the first time. If the date and time are not set correctly, the measurement values stored in the memory and the average values may not be correct.
1. TO START THE SETTING
Press the Date/Time Setting button ( ) to adjust the date and time.
The year flashes on the display.
2. SETTING THE YEAR
The year can be set between 2010 and 2040. When the
display reaches 2040, it will return to 2010.
Press the Up button ( ) to advance by one year.
Press the Date/Time Setting button ( ) to set the current
year.
The month flashes on the display.
NOTES:
• Press the Down button ( ) to decrease the date and time values.
• Press and hold the button to increase or decrease the date and time values faster.
3. SETTING THE MONTH
Press the Up button ( ) to advance by one month.
Press the Date/Time Setting button ( ) to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the Up button ( ) to advance by one day.
day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the Up button ( ) to advance by one hour.
Press the Date/Time Setting button ( ) to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
Press the Up button ( ) to advance by one minute.
Press the Date/Time Setting button ( ) to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE:
The monitor will automatically turn off five minutes after the minute has been set
SOURCE (PDF User Instruction Manual):
http://omronhealthcare.com/wp-content/uploads/BP742_IM.pdf
Jan 03, 2015 | Health & Beauty
Panasonic PT-AX200U projector. input display flashes on and off.
It could be your source and not the projector. If it is a laptop then hit function four and change how it shares display. Over all I need more info as to how it is plugged in and what you are trying to view from.
Jan 08, 2013 | Panasonic PT-AX200U Projector
Have a kenmore elite he3 which stops the cycle w/ 40 min. remaining and flashes back and forth the 2 initials ''F'' and ''H'' on the screen. Don't have a manual to check
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display.
  1. Unplug the washer from its electrical source and wait for 30 seconds.
  2. Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
  3. The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
  1. Check all hose connection and valves, both hot and cold, are turned on completely.
  2. Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
DrakeTech
Feb 23, 2010 | Washing Machines
My HDTV seems to be very Low Def - Panasonic Projection PT47WX54J
Ur convergence it dead.Must replaced the 2 convergence ICS.Know how to solders?Tries Tv repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The Shop will cost U $300 parts and labors.
Jan 27, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Loses source signal to the PC after heating up.
I would first make sure the cable is not having an problems. But when I worked at a repair shop the main board was always the problem when giving these symptoms.
Nov 13, 2009 | ASK Proxima M1 Multimedia Projector
The display flashes...
unplug everything. press power button continously for one minute.
helps sometimes. sometimes repeating multiple times helps. sometimes repairs the issue for a few months and then finally breaks for good.
Mar 23, 2009 | Gateway XHD3000 LCD TV
Proxima Ultralight x350 no valid input source error?
reset the settings to factory default. if that doesn't work, the lamp may not have enough power to stay on. if the lamp doesn't have many hours on it, it's the ballast.
Jan 05, 2008 | InFocus Proxima UltraLight SP1 Multimedia...
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Toshiba 32HLC56 32 in. HD-Ready LCD Television Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
