Question about Frigidaire GLTF1040A Front Load Washer
Frididaire front loader problem
Front loader frigidaire is not spinning water from clothes what might the problem be.
  • 4 more comments
  • lyjordan Jun 17, 2008
    clothes are soaking wet not spinning
  • His Own Sep 18, 2008
    My husband took our machine outside to deal with a different problem. When he brought it in he bumped the control knob on the doorknob. Now it drains and spins about half the time. The rest of the time I have to spin the knob to the drain and spin spot, and hope for the best. Sometimes I have to do this several times. It is such a waste of time. Is there a fix for this?
  • robinmarsh20 Mar 30, 2009
    Half the time the unit will not spin out and the clothes are wet. I can move the knob around and experiment until I can find the spot where the spin will start. The unit is about 6 years old. My email is robinmarsh2000@yahoo.com.
    I would appreciate any advise you can provide.
  • His Own May 11, 2010
    In my case the water does not pump out, and then it does not spin.
  • robert samples May 11, 2010
    is it not spinning at all or not draining the water out
  • Anonymous Mar 17, 2014
    frididaire front loader locked
    President:
  • 1,314 Answers
Send me an e mail at b4829@yahoo.com
Posted on Jun 17, 2008
I cannot find my pump filter on my front loader washer.
mine is front right hand side underneath the washing machine
Feb 12, 2012 | Frigidaire Washing Machines
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader--not spinning and not draining
Replace the control board--it runs the entire process.
Jul 26, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire front loader washing machine. If there are only a few lightweight pieces of clothes, the water will not spin out. Also some of my clothes have spots on them after washing. What do I do?
For the odor, you might try running a cycle with a strong bleach solution (no clothes!!!). Leave the door open when not in use to air out.
Certain Frigidaire models will not spin out if the door switch is damaged or is defective.
Unplug the machine first before doing this!!
You can access the switch by removing the top (remove two screws from the back of the panel). To remove the switch, remove the two screws from the front of the machine where the door latches. Locate the switch and observe how the wires plug into it. Replace with new switch.
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frididair GLTF1670AS Front loader washer problem-water will not run in
IT could be the water heater element it would prevent it from moving to next cycle . Close Ireland bye bye
Nov 13, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1040A Front Load Washer Logo
221 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
