Question about Whirlpool Washing Machines
Agitator doesn't agitate properly - Whirlpool Washing Machines
    President:
  • 1,654 Answers
How old is this machine? There are several small plastic tabs that make the agitator work and these break after time and have to be replaced. They are cheap and the repair should not be expensive if this is the case. This is the first place I would look. If you can spin it by hand and there is not much resistance that would be a good clue. I assume the motor is fine and it spins and pumps normaly? You might want to get the motor coupling replaced at the same time because they usually last about the same amount of time. This too is an easy and somewhat inexpensive repair.
Posted on Nov 11, 2010
  • Dcramer531
    Dcramer531 Nov 14, 2010
    .Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
    2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
    3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
    4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
    5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
    6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
    7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
    8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
    9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
    10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
    These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
  • klynn225 Nov 14, 2010
    Thanks for ur response. I pulled the agitator cap off of the top and sure enough I saw right away the teeth inside the agitator and how the dogs grip those teeth as it agitates. It made so much since. Anyway the dogs were worn out. Very simple job to fix at home. I found an app. store here and bought the dogs and an "O" Ring for the cap. Thanks so much...I saved so much money.
    Kathy G. Athens, PA
Will not spin or agitate
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Nov 26, 2012 | Maytag Legacy Series Top Load Washer
How to remove the central spining part of the washing machine
do you want to remove the agitator?watch this video,it will show you how to remove the agitator,this is showing a repair on the dogs but will help you get the agitator off,once you remove the screw you can pull the agitator up and out.hope this helps you out.
http://www.youtube.com/watch?v=0GQh8JLqVv8
Apr 29, 2012 | Whirlpool Washing Machines
I have an kenmore elite top loader washer model 110 27087602. During the spin it makes loud clunking noise. I seen the other post about the agittor nut sometimes loose but I do not see this nut under the...
The most probable thing that is making that noise is a broken motor coupler if it drains but the tub doesn't move or even if the agitator doesn't move (espically the lower section) on the wash cycle the coupler is the problem. I have included a youtube video that will show you step by step how to replace the coupler http://youtu.be/9K1KHEogf3c
If it does agitate let me know and ill tell you how to completly remove the agitator to check that drive block you refer to as nut under softner dispenser
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Washing Machines
I have a HotPoint washer (VBXR1090D) and it stopped agitating. It still spins, and everything else, just doesn't agitate.
Do you here the motor running on the agitation cycle yet it doesn't agitate? If so the agitator coupling is the problem.I have included a youtube video that will show you step by step how to repacle the coupling.The part number in the title of the video(WH49X10042) is the part number that you would need(Hotpoint is made by GE) it could be ordered by simply googling that part number
here is the lik for that video http://youtu.be/N26MCQKuXn0
I hope this helps and if it does please give me 4 thumbs up
Gene
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Will not agitate
Since the agitator is connected to the timer I think you may have a bad timer, or control board. If the pump is not starting then it sounds like it is siphoning out. Raise your drain stand pipe, and if it is already raised enough, get a anti-siphon devise to attach the drain hose to the stand pipe. If the tub doesn’t fill to the proper level, it will not go into the wash cycle hence there will not be any agitation.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Washing Machines
My washer stopped adjutating but it drains the water out what is the problem
The agitator is driven by a couple of different methods. The first is the agitator is spline and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling.
If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Aug 07, 2009 | GE Washing Machines
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
-no agitation
Hello
Welcome to Fixya
My name is Huum,
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 10, 2008 | Maytag PAV2300 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
