Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
Want to downlaod to computer via usb, but computer doesn't see device
    Genius:
  • 1,177 Answers
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Posted on Nov 11, 2010
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
When I attached the external HD via USB it doesn't show up on my computer.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of :unforeseen problems:
hope this helps
Jul 07, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I have a white apple ipod. Model a1136 (30gb) which i am having a problem connecting to the computer. When I try to connect it, it reads "One of the USB devices attached to this computer has...
Believe it or not, many people have resolved this issue just by unplugging (from the wall or the power supply, doesn't matter) the PC for 15-30 minutes. (This allows all the capacitors on the motherboard to fully discharge) If you have a laptop, unplug it and remove the battery.
If it only happens with the iPod and no other USB device, let the iPod drain down completely and plug it back in.
Other things to try: A new USB cable Uninstall ALL the USB ports from the PC via Device Manager and reboot.
Jun 29, 2011 | Computers & Internet
I have brought the Dazzle Platinum PVR with Pinnacle Studio HD 14 and the studio says there is 'no device found' when my Dazzle is connected to my laptop via a USB port, what do I do to get the studio to...
I haven't used this program myself, but speaking from experience in using similar programs, there might be an option inside the preferences menu, where you need to set that device to the current connected device in order for this program to recognize it.
If that doesn't work, go to Start > Programs, then look for the Pinnacle application. Right-click on it and select Troubleshoot Compatibility.
If that doesn't work, you can try updating the Driver and the Firmware of your device through the manufacturer's website. Maybe the device itself is not installed on your computer correctly. Plugging it into the USB doesn't assure that it's going to be working properly.
If you need more specific information, or if you need any additional information, return to this page and post a response. I'll be happy to assist you further.
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
May 03, 2011 | Pinnacle Dazzle DVD Recorder
I cannot conet to the computer using USB cable
You need the LG PC Suite application running on your PC. In case you don't have it, downlaod it from this location, install and run it. Then, on your phone, go to 'Menu > Settings > Connectivity > USB connection mode' and set it to 'Data service'. Connect it to your PC via USB and follow the prompts.
Hope it works for you.
Cheers! Carlos
Apr 22, 2010 | LG Secret ? KF750 Cellular Phone
It wot let me downlaod songs on my psp. how can i downlaod songs on my psp?
- Make sure you have a folder called MUSIC in the root of your MS.
Drag & Drop music into MUSIC via a USB.
- Make sure your MS has enough space to store your music!
Nov 06, 2009 | Sony PlayStation Portable (PSP) Console
My system can not access sound drivers. system is Intel D865 GLC. Also cant access the USB drives.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=950&lang=eng
select your operatign ssytem from this link and downlaod audio driver.
Aslo downlaod inf update utility then install in your computer.
For usb device right clci kon my computer then click on proeprty then go to hardware ->device manager
Then uninstall all usb drivers then restart the computer then check.
Also check your usb ports of computer are working fine.
You can check your bios settings to .
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to advanced and enable USB LEGACY 2.0
then save settings and exit
Also try to usb drives to another computer if it works there then connect again to this computer and right clicck on my computere then click on manage then go to disk management then removable media then right clci kon your drive then click on open or explore.
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Computers & Internet
Need to backup content of Windows 98 computer via USB device
install XP next to win 98 on a separate partition, XP will automaticlly create a bootoption. If not possible, install XP over win98. documents etc will remain intact if you have enough diskspace.
If both are no option, create a backup from windows98 and than copy that one to any USB drive. Backing up from 98 takes veryvery long and so doesn copying to USB.
Jan 15, 2009 | Veritas Backup Exec 10 for Windows Servers...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
230 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
