Question about Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game
Park and sun goal manual - Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game
Mitsubishi mirage 1996 immobilizer wiring layout
what is goal, move car 10 feet or 10 miles>
we can not guess goals.
but you can unlock the parking shifter. right?
but there are 3 locks.
  1. park lock
  2. steering lock
  3. and ENGINE EFI lock outs.
to move any car no key you must defeat #1 and 2.
number 1 is easy the console , park defeat lever. gets you to neutral easy.
the steering is big problem huh? no key
if you can get it to neutral, you can push any car.
but turning is an issue.
having only 1 key invites this. , if you had even 1 spare metal key
the steering would be free.
May 05, 2014 | 1996 Mitsubishi Mirage
Wheel is hot
Cover the windscreen from the sun light while parking.
Jan 25, 2014 | Toyota Avensis Cars & Trucks
Do I need to turn off my aquarium light at night?
Most fish, like us, need to have a day and night. It is important to try and simulate a natural environment for your fish. That being said, you goal should be to mimic the sun. So, yes you should turn the light off at night, as the sun would naturally set over the ocean.
Aug 14, 2012 | Fish
I have a 2008 Yamaha WR250R that gets "Sunstroke" will not start when left in the sun
Hi, Scrappydoosr some bikes get "Sun Stroke" after running fine in the morning then shut off and parked in the sun for a couple of hours on a hot day. You get back on the bike hit the starter button and nothing happens or the engine turns over but will not fire. Then you put the bike in the shade for 20-30 minutes and it fires up no problem.
The primary reason for this phenomenon is faulty wire connections in the Starter and/or Ignition Circuit. You may have a wire connection/component that makes just enough contact when cool to start and run the bike, but when parked and exposed to direct sunlight heat causes expansion and creates an "OPEN" in the circuit not allowing the bike to start. You move the bike into the shade for a few minutes, the temperature goes down allowing the connection to contract and make better contact and suddenly "it's a miracle" the bike starts. I know what you're thinking that Gremlin could be anywhere, and you would be right in that assumption, you can take your bike to a dealer, spend tons of "DRACHMA" only to receive validated nervous emotions the next time you park in the sun, then 1 week later it doesn't start. Start by doing a ground check:
Check the battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Check all common grounds for the same suspects.
The secondary reason your bike may get "Sun Stroke" is vapor lock although this is a rare scenario it does happen.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
HELP WR250X Starting Problems
For those who have trouble starting their bikes after parking under hot...
Yamaha WR250R Service Manual
OEM parts for Yamaha
Yamaha WR250R Owner Manual
Jul 03, 2017 | 2008 Yamaha WR250R
Filled our Intex pool on July 1, 2011....put salt in the water was crystal clear...ran the salt water system...and by July 3 the pool was a light yellow color...now what?
Get your water tested.
Here is what you must do when you fill your pool ... 1st, get the metal out. Use a sequestering agent, follow the bottle instructions exactly. 2nd, get the alkalinity proper (goal is 100) 3rd, get the pH proper (the goal is 7.4). 4th, introduce your salt (should be about 3200 ppm) Check the balance using the Taylor Water Balance Wheel. Getting your water correct may take several days.
Another thing you should consider is using cyanuric acid (aka stabilizer). Cyanuric acid acts like sun screen for your chlorine. The sun will eat your chlorine almost as fast as you make it if you dont use Cyanuric Acid.
I hope this helps you out ... you can get additional free advice from your professional pool supply store. Stay away from the discount place for best results.
Thanks for your interest in FixYa.com
Jul 04, 2011 | Intex Automatic Salt Water System for ...
My 1yr Old Yamaha R15 doesnt Start when kept in Hot Sun
Hi, Anonymous some bikes get "Sun Stroke" after running fine in the morning then shut off and parked in the sun for a couple of hours on a hot day. You get back on the bike hit the starter button and nothing happens or the engine turns over but will not fire. Then you put the bike in the shade for 20-30 minutes and it fires up no problem.
R15 fuel pump heat up problem bike do not starts till it gets cool down
https://www.quora.com/Why-won%E2%80%99t-my-Yamaha-R15-start-immediately-after-being-parked-in-direct-sunlight
Yamaha YZF R15 Service Manual
Yamaha YZF R15A Owner Manual
May 15, 2010 | 2008 Yamaha YZF-R15
Hi, Jeevith17 some bikes get "Sun Stroke" after running fine in the morning then shut off and parked in the sun for a couple of hours on a hot day. You get back on the bike hit the starter button and nothing happens or the engine turns over but will not fire. Then you put the bike in the shade for 20-30 minutes and it fires up no problem.
https://forum.motorcyclenews.com/topic/59006/yamaha-custom-wont-start-in-hot-weather
Yamaha R15 DIY Fuel Pump Repair Team-BHP
Mar 29, 2010 | 2008 Yamaha YZF-R15
PLEASE tell me how to change the goal on the Wii Fit? It says that you can change your weight goal any time, but I pushed every button and read the manual and I can't find out how to do it.
The only way that I know how change your BMI goal is to wait until your goal time is over and change it when the balance board guy says that you can create a new goal.
Oct 29, 2009 | Nintendo Wii Fit for Wii
Alam goes off when park under the sun. It seems like it doesn't like to be park outside when it's hot
give her some flower and say sorry... hhhh
now really...
check the power cable meybe the sun hit it if not you need to go to the garage.
Jul 22, 2009 | 1998 Audi A4
Will not go into gear
parking pawl is not biting WOW !!!if the linkage is okay from shifter to transmission the parking pawl ( a metal arm ) that locks the sun shell or known as the direct clutch drum is broken mechanically... check the linkage first ... and check the movement of the manual valve. thats the valve your gear shifter moves you can see it move if you drop the pan....
May 07, 2009 | 2000 Mazda 626
Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game Logo
53 people viewed this question
Top Park and Sun Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Park and Sun Toy Expert? Answer questions, earn points and help others
