Question about Philips Magnavox Learning Universal Remote
Remote for Dish Tv control
I just had Dish TV installed and they can not make their controler work for volume or to turn off and on my tv they have tried all their codes and said the TV is to new can you help
    Sergeant:
  • 234 Answers
Hi! i think remote controller fell down! The remote board damaged and cracked because of that only remote (button two only) not working! you use multi-purpose remote then you switch on DISH TV.
Thank you..........
Posted on Jun 17, 2008
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
  4. Press 0.
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
I need a remote control code for tp 3730
tony_ballard
I could not find a code for that TV brand but I have provided instructions on performing a power scan to possibly find a code with your DISH remote that will work for your TV. I hope this helps.
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Mar 21, 2011 | DISH Network IR Remote Control
I got my dish network to turn off the tv and adjust volume but remote wont turn on the tv
Hi there!! This is Kimberly Escobar with DISH Network, just ran across your post and wanted to provide you with some helpful information to help get your problem resolved. If your remote control is functioning as far as turning the T.V off and the volume, one of the things you may want to check is that the power button is working, you can verify this by trying to turn on and off the receiver. If it works for the receiver you will need to try to address the remote to your T.V again using different codes. To address a remote to the T.V we use certain codes that integrate to the remote allowing it to function with the T.V. unfortunately we cannot promise the remote will function the T.V completely. You can find more codes at this link here http://www.dishnetwork.com/SupportSection/remote-setup. If you need any additional help please free to contact us directly at 1800-333-DISH. Hope this is helpful to you.
Feb 10, 2011 | DISH Network IR Remote Control
Hi, i bought dish universal remote . all buttons working but volume buttons not so please help me. my old remote was 1.5ir and new has 3.2 ir universal
Hello, it sounds like all that you need to do is program your remote to the tv. Because I do not know the brand of your tv, I'll give you the power scan instructions. The power scan scans the tv for the correct remote code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Hope this helps!!
Becki Barned
DISH Network Customer Service
Feb 02, 2011 | DISH Network IR Remote Control
Volume control on sanyo tv to dish controler
hy2277
I have provided a link on how to program the remote to your TV so you can control the volume and turn the TV off/on. I have also provided the codes available for your Sanyo TV. I hope this helps.
Instructions on programming the remote to TV:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Nov 07, 2010 | DISH Network IR Remote Control
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
-Kirstie DISH Network
Sep 16, 2010 | DISH Network IR Remote Control
Get volume and on/off button to work on dish remote
Hello, you may have already gotten this resolved, but here are some simple steps to get this resolved. Just follow this link to our website, and you will be good to go real soon!!!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
Jul 31, 2010 | DISH Network IR Remote Control
Philips Magnavox Learning Universal Remote Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
