Question about Gateway Solo 5300 Notebook
While using the computer it shut off and now can't restart. I begins to boot, then squeaks and turns off. I continues to start up and stop.
  • 23 Answers
Consult an engineer...may be the hard disk has crashed..
Posted on Nov 11, 2010
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
I restored T5048, but now it shuts down and restarts non stop ?
Shuts down and restarts the boot process automatically continuously. Try turning it off, then hit the power button and immediately start hitting the F8 key repeatedly until you see SAFE Mode. Scroll down and see if you see an option to Cancel or Stop automatic restart on system failure. If you do click that and try rebooting your machine. It should tell you what exactly is the problem so you can read it without it rebooting all the time.
If it's that you need a CMOS battery you're in luck. Just turn the computer off, remove the case, sit the computer on it's side, get a flashlight and look inside for a battery about the size of a nickel. Normally the size of the battery is CR2032 which can be purchased at Walmart or you local grocery or drug store for $5.00. Just use a small flat head screw driver to remove the old battery and pop in a new one.
Mar 20, 2012 | E-Machines T Computers & Internet
My daughters desk top computer will boot up when I press f1 and then it shuts down and brings me back to a black screen and tells me to hit f1 and reboots. When the windows does come up I dont have time to...
Remove the battery from the motherboard and check that it has 3volts or above. if not then replace it. That will cure your pressing F1 to continue all the time. As for the restarts then you will need to turn off Automatically restart in the control panel,system section. To do this you will need to boot into safe mode. Tap the F8 while booting until you get a black screen with white type on it. Its first option is to boot into safe mode. hit enter on this screen and windows will start with no drivers loaded. the screen will appear very large. navigate to the control panel as mentioned above and untick "automatically restart". Ok that and reboot normally. now you will most probably get a blue screen of death. note the first stop code. it will appear something like 0x000000??. Its the last two digits that are the clue to why this is happening. Google the stop code and you will now know why this is happening and do something to stop the problem.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
Acer aspire one model gz5 showed hibernate on screen, low battery. turned off. recharged battery, now there is a dark screen, manual was no help
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Jan 10, 2011 | Acer Aspire One Netbook 8.9" Notebook
I turn my computer on and the screen is black, what can I do?
2.
3.
4.
5.
6.
Jan 10, 2011 | Sony Vaio P VGN-P530H Netbook
My laptop is not startting i have a black screen that shows A DISK ERROR OCCURRED PRESS CTRL+ALT+DEL.. HOW CAN I FIX IT? i already try re -started i does not work.
You will have to start in safe mode so follow instrucitons below
2.
3.
4.
5.
6.
Chris Thrash
B52Computers
Jan 10, 2011 | Toshiba Satellite Pro L300 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
