Question about Siemens HG2415UC Stainless Steel Gas Kitchen Range
Oven does not lite only on broil - Siemens HG2415UC Stainless Steel Gas Kitchen Range
  • Siemens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 11, 2010
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
How do I set oven to broil its a 2004 kenmore to broil?
Please go this website for a complete owner's manual for your oven:
www.kenmore.com/ccownersmanuals/nb-100000000410016
Jan 11, 2013 | Ovens
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Oven door will not open
The lock motor (latch) has gone bad. Unfortunately, the part has been discontinued and is no longer available for this model.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Amana AOCS3040 Electric Single Oven
I have a Spectra XL44 gas oven. The stove and broil work fine but the oven will not lite the ignitor doesent even try to lite up or anything. Do you think the ignitor just needs to be changed or may there...
most likely it's just a bad ignitor,remove the ignitor and check it with a meter to be sure but it's common for the ignitor to go so i'd say install anew ignitor and you should be all set.
Apr 26, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Kenmore oven with no directions. We cannot get the broiler to work. Can you tell us how to do turn it on? billiejack69@hotmail.com
Here's the manual for your oven, based on the model number you provided.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0522659.pdf
If this isn't your oven, use the following link to enter in your model number to get the correct manual, free.
http://www.managemyhome.com/mmh/ (click on the manual tab)
Hope you find this Very Helpful and best regards!
Here's how to use the broil function of your wall oven:
Press the BROIL pad. (This will
automatically set HI Broil).
lb. While the set indicator is flashing
in the display, press the BROIL
pad again if you prefer to use
Lo Broil. Use Lo Broil to cook
foods such as poultry or thick
cuts of meat thoroughly without
over-browning them.
2. Press the START pad.
3. When broiling is finished, press
the CLEAR/OFF pad.
Aug 28, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
24: gas oven 30425
you will need to replace that bake ignitor which comes as an assembly with the burner bar, it is part number 8190618 .this will cost u $50.00.   That should solve it. rate the solution if it hels u. feel free for further assistance. thanks
Nov 10, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
HBL 745 - stopped working
seems the oven was locked by the kids by mistake - found the manual and unlocked it.
Oct 14, 2008 | Bosch HBL 745 Stainless Steel Electric...
Kenmore 24" built-in oven wont heat
HI THANKS FOR THE QUESTION oN SOME MODELS THERES A FEATURE THAT IF YOU USED THE TIMER OR THE TIMER SETTINGS MAY HAVE BEEN ACCIDENTLY BEEN CHANGED CHECK TO SEE IF YOU HAVE THE KEEP WARM SETTING ON THE TIMER OR A BURNT OUT BAKE ELEMENT THANKS THEAPPLIANCE DOC
Sep 12, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Siemens HG2415UC Stainless Steel Gas Kitchen Range Logo
434 people viewed this question
Top Siemens Kitchen Ranges Experts
R.A. Ellis
R.A. Ellis
Bill Boyd
Richard Warren
Richard Warren
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
