Question about Master Heaters B155DST
I am out of town and don't know if i have to unplug my heater when the diesel runs out
  • Master Heaters Master
  • 43,501 Answers
Don't worry.... when it runs out of fuel it will flame out and then shut it's self down...
heatman101
Posted on Nov 11, 2010
My heater hoses have been removed and bypassed. I need a heater hose diagram for my 1998 chrysler town and country van with a 3.8 L. I don't know which hose will plug into which heater core tube
That's easy
Drive around back of a dealer,walk in the open
service bay doors & ask a tech to come out &
tell you.
I walk into dealers all the time, anywhere I want to go,
& never get stopped
If your questioned your just looking for the parts dept & leave
Feb 01, 2013 | Cars & Trucks
Will cal spa run with temp sensor unplugged
The temp sensor is a switch that turns the heater off if the water is too hot or too cold. Unplugging it would make it off. So replace it. I got tired of replacing mine that kept breaking so I hard wired the sensor connectors so it's always ON as far as the heater knows. But I don't recommend anyone do that as this would increase chance of fire.
May 05, 2012 | Pool & Spa
1998 lincoln town car when i turn the temp to 90 it still wont get hot have changed the thermostat, and flushed heater core but it still won't get hot the AC works great just don't have no heater...
Just a stab at it................see if there's a vacuum or electric operated valve in the heater hose lines.Trace it out.The heater hose goes from the thermostat area at intake manifold thru the heater core,and back to water pump area. don-ohio
Nov 01, 2011 | 1998 Lincoln Town Car
Can no longer buy home heating oil in the country town I live in. Will my Vulcan oil heater operate with Diesel?
no how will you light it , no find heating oil some where else , would not be safe to use Diesel
May 29, 2011 | Heating & Cooling
Heater runs for 2-3 minutes then shuts off, just like it was unpluged. we have cleaned unit as best possible. thanks, DON
I would love to help you.
Please respond by PRESSING REPLY OR COMMENT
Don, have you tried a different outlet yet?
Bruce
Jan 13, 2011 | Reddy R155D Utility Heater
Running very rich. how to adjust fuel and air screw
First of all are you running kerosene or diesel ? If you are using diesel, it does not burn as clean as kerosene which causes that burning rich smell. If you are going to use diesel, just use #1 diesel only but still may have a little rich smell. Don't use die red off road diesel. If you are using kerosene and want to check your air pressure on your pump, you will need a 10 lb. test gauge with a 1/8" NPT male pipe thread on the end of the gauge.There are 2 plugs on the back plate. Do not remove the upper plug with the hole in it. This is the adjustment screw for pressure. Clockwise increases pressure, counter clockwise decreases pressure. With the heater unplugged,remove the lower plug. Screw the test gauge in and start the heater. Check the pressure. Most are set between 5 1/2 and 6 lb. of pressure. Check your owners manual to see what your setting should be. If your pressure does not change, you have a worn pump and it would have to be repaired. Once you have the correct setting, unplug the heater, remove the gauge and install the plug back. If you feel that you are not qualified to perform this procedure, send it in to a local repair center.
Jan 11, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ford f350 diesel truck 30 amp fuse keeps blowing.
Dec 27, 2009 | 2000 Ford F350 Super Duty Super Cab
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fuel Types
Burn only #1 deisel. I'm not sure what red deisel is. I do know the machines are temermental and can gum up easily.
Jan 05, 2009 | Rinnai Toyostove Direct Vent Heater:...
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Master Heaters B155DST Logo
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Paul Carew
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
