Question about Kenmore HE2 Plus Front Load Washer
My Kenmore HE2 is flashing F-24 on the little screen. What does this mean. It hasn't finished the cycle. I have it set on Stain Treat/Normal.
  • janetlreynol Nov 11, 2010
    What can I do in the mean time? What buttons do I push to get it to finish the cycle? I've seen it do this in the last week and have had to turn off the machine, then Rinse/Spin to get to excess water out of the clothes. do I need to have a repairman come out?
    President:
  • 1,891 Answers
Remove the three 3 screws in the fornt panel below the door and inside on the right side of machine is a plastic pack in it is the tech sheet . the codes are on it and it will tell what is causing this code and what to do with it . i belive that if you clean the pump clean out located just right of center in front and behind the front panel .. the problem will be over . if the code covers something else . then you know what .. we gota do it too . but always clean the pump a couptl times a year .. it s just good maintaince .. mm hope this hepls and thams for using fix ya ..
Posted on Nov 12, 2010
  • 5,081 Answers
The error code which you have mentioned indicates water temperature failure.
To exactly diagnose it we need an ohm meter t check the resistance across the temperature sensor.
Try this only if you are handy enough in doing this and do not forget to disconnect the supply while trying out anything.
The part number is 8181705and it costs only $10 to $15.
So you can replace it and this problem must be solved
Posted on Nov 11, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Nov 11, 2010
    http://www.fixya.com/support/t3495165-er...
    Check the above link for an detailed answer on this problem by one of our senior experts.
  • INDIRA KUMAR
    Do you have experience in working with the internal parts of your washer?
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Panel is switching back between 6 and F at the end of the cylce
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/639d1187051794-he2-error-codes-he2-error-codes.pdf
Above is a link for the error codes and what they mean.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above is your service and repair manual. with troubleshooting steps, to isolate your issue.
Jun 22, 2010 | Kenmore HE2 Plus Front Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
HE2 Plus blinks F-11
Look for the technical brochure. Mine was on the lower kick panel taped inside. I would not take off the back panel first. Maybe the top or the lower front if it is a front loader. It tells you how to do diagnostics and what the codes mean.
Jul 22, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
HE2 front loader error code
According to the HE2 Tech Service manual, it means "Suds Lock (Overdose of detergent detected during the wash cycle).
Aug 29, 2008 | Kenmore 43142 Front Load Washer
Normal wash flashing Red
We have the same problem with kenmore model 66513839k600
we press light wash and normal wash lights up, we have to wait over a month for sears to service. This will be the second control panel they will install on warranty, a month is far too long a wait for service on any appliance.
Dec 03, 2007 | Kenmore 24 in. 17039 Built-in Dishwasher
Kenmore HE2 Plus Front Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
