Unit shuts off and pilot will turn off w/o reaching the proper temperature. The unit is a direct vent heater, brand new. The installation manual was not box.
    Genius:
  • 1,015 Answers
Is this thermostat controlled or by control on unit. If it's thermostat I would check to see how far from set point it is off. 4-5 degrees difference from t-stat and actual temperature is not unusual. Does unit come back on if you turn it up? Sorry I'm not much help but I need more information.Thank you.
Posted on Nov 11, 2010
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
My pilot stays on on my propane furnace but will not light up
The Little Giant units use a Unitrol gas valve very similar to a water heater in the home. #1,urn the Unitrol gas valve to the "PILOT" position to ignite the pilot. Depress the plunger and hold it down then push the spark igniter button until you can see the pilot flame ignite.
You have a lit pilot so this is not a problem for you.
The pilot light stays on continuously by design.
Once the pilot flame is established, you then turn the on/off/pilot valve to the "ON" position and set the thermostat to the desired temperature range., it should then fire its main burner until the desired temperature is reached. Once the temperature is reached, the main burner will shut off and the heater will go into a standby mode with the pilot flame still burning.
If you have turned the pilot valve to on and set the temperature high, it should come on, if not a new gas valve is required, they can be very difficult to replace due to rust.and most cases require a new unit,
Mar 19, 2015 | Unitrol Propane Heater Valve - Little...
Why does the heater turn off?
If it's thermostatically controlled, if shuts off the burner when it reaches the set temperature. Is the pilot flame going out too? These heaters require a certain amount of fresh air to operate properly. If the oxygen level gets too low, it is designed to shut off completely for your safety.
Mar 15, 2015 | Procom 10K BTU, Vent Free, 2 Plaque...
How do I fix the heater? The igniter will not stay on long. The heater never reaches desired temperature.
Try turning it off and unplugging it for 30 seconds. If that doesnt work, some people I know had to melt ice from their vents with a blow dryer. If not call a technician. Error codes should be in the manual. http://www.rinnai.us/customer-care/manuals-literature
Feb 24, 2015 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a direct vent gas fireplace (MHSC series cdvsc7) that will light but will shut down after about 3 Minutes
you have trash in your pilot is not proper power light is not on please blow out are vacuum your pilot will sometimes help
Nov 29, 2014 | Heating & Cooling
Richmond direct vent water heater
The pilot lights then heats/sends a signal to open gas for burner then(burner)should stay on but if valve shuts the gas off,then have your unit checked. What ever you do,DON'T MESS WITH IT IF GAS/FLAME ON!!!!!. These systems come with a safety feature that allows gas to go on only when safe!!!!
Mar 30, 2014 | Water Heaters
Piolite light keeps going out after unit turns on and reaches temperature set on thermostat.
Check gas pressures standing and working make sure pilot burns correctly and thermocouple is in good order
Dec 13, 2010 | Empire DV-215 Direct Vent Natural Gas...
Propane heater goes out after heat cycle
I've seen excessive draft draw the pilot flame away from the thermo couple when the burners light so when the burners shut down so does the pilot.
Feb 08, 2009 | Coleman Propane Forced Air Heater...
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Williams wall furnace, top vent.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Dec 13, 2007 | Heating & Cooling
Open Questions:
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
