They are very corroded and rust fills many of the gas discharge holes
  • 81 Answers
What kind of unit are you talking about?
Posted on Nov 11, 2010
I have a Ridgid 5 gallon stackable air compressor that when I shut the compressor off, all the air discharges from the tanks. Do you know what the problem is?
You don't say how old this unit is. I had an older one and it had a small rust hole in it's tank. Had to get rid of it because the tank was rusted bad on the inside. Also check all the lines as they could be leaking as well. Also the one I have now leaked air because the compressor was low on oil. I got compressor oil and its ok now. Do not over fill as it will blow oil all over.
Dec 05, 2017 | Ridgid Air Tools & Compressors
Why is it hard to fill the gas tank, it only takes it slowly?
Most likely the gas filler neck has rust holes. There are also several hoses on the neck that can deteriorate with age. Repair or replace.
Jul 09, 2014 | 1998 Subaru Forester
Rusty fuel tank
Ive personally never seen a stainless steel tank on a factory vehicle .. i cheap fix is to take a couple old stereo speakers and take the magnets from the back of them , stick them to the bottom of the tank away from the pickup . it will hold the rust particles to that one area and will lesten the chance of them getting through the system . Another cheap yet more time consuming fix is to by Red Kote gas tank liner from your local part store . Drop the tank and clean and coat it .... Otherwise , buy a new tank....
Nov 20, 2017 | Desa International Reddy Heater R40 40,000...
Gas leak from tank when filled and constant smell of gas
The tank's filler tube may be leaking either at a hose clamp connection or metal tube rusted away and has holes.
That's what hapened to my 1990 Cadillac Deville, anyway. Had to replace the filler neck.
Jul 04, 2010 | 2002 Jaguar X-Type
Leaky fuel fill pipe
Is it rusted and leaking,only when filling at gas pump? Check where leak is. eg rubber hose or pipe. You can remove and solder pin holes. Kind of old to look for a new part.
Mar 15, 2010 | 1994 Pontiac Grand Prix
Check gas cap light comes on, i clear the code but comes back every 50 to 75 miles
I bet you have a rust hole in the fill tube going to the gas tank.
Mar 02, 2009 | 1998 Cadillac DeVille
When i fill up the gas tank the alot of gas comes out the bottom onto the ground
You probably have a leak in the fill tube that goes from the gas cap nozzle (where you fill the gas) down to the tank. If you get under the car, or look up through the wheel well (you might have to remove the liner in the well), you should be able to see the fill tube. If it's old, cracked, worn, broken, or has a hole in it, that'd do it for sure. That's my bet anyhow - either a leaking tube due to damage/rust, or if it's a two-piece design, a clamp that has failed and isn't sealing the two halves together.
Jul 26, 2008 | Ford Escort Cars & Trucks
Gas Stove Top Burners
The burner are fixed only maintenace are to clean burner /clean holes and edge in order flow of gas good performance.At the back if you want make more good performance of your top burner clean the nozzle where the air and gas mix . Clean the nozzle w/fine niddle /sometime if will corrode with rust and dust to struck flow of gas.
Dec 23, 2007 | Dacor Preference SGM466 Gas Cooktop
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
