Im getting and error E020 0150 on a canon CLC 1120 I know it has something to do with the magenta dev setting how do i resolve this Thank you
  • 1 more comment
  • yan dikshteyn Nov 11, 2010
    doesnt exactley help fix this issue
    ok but will the code come Back? and the magenta color is off it s darker than normal how do i set that.
    Thank You
  • yan dikshteyn Nov 12, 2010
    thank you
You will need to go into the service mode and then press function, clear, and then error. Now, turn machine off and then unplug from the wall and reconnect it and turn you machine back on and the code will go away.
Posted on Nov 11, 2010
  • 340 Answers
E020 - The toner is not adding correctly into the developing assembly.
1) If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) If the hopper is 1/2 full or less, the worm gear splits under normal use.
1) Advise customer to add toner only when the toner light is lit, right away, and replace toner motor, or 2) Just replace toner motor (FH7-1762-030).
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller. It has been noted that some DC controllers do not provide sufficient current to drive the hopper motor. Replace the DC controller COL97.08.25 M0000244.txt.
  • 12,061 Answers
Clc 700s E020 error
Your cartridge is not conected Yellow&magenda cartridge mg Roller earth connect
Mar 13, 2009 | Canon CLC 1120 Color Copier
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
E020 02FF Error
the problem this in tolva of cian
Sep 05, 2008 | Canon CLC 1120 Color Copier
Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Jun 19, 2008 | Canon CLC 1120 Color Copier
CLC 1120 code e071, sub code 001
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors ther may be toner or paper dust.
May 20, 2008 | Canon CLC 1120 Color Copier
Error code is 0180
mr rupabai your problem is in the magenta starter try to intialiaze it again by pressing " 28 at the same time
copier
function
install
int m press it and wait a few minutes if an error occured after intializing change the magenta starter and intialized again
Mar 21, 2008 | Canon CLC 1120 Color Copier
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Jan 29, 2008 | Canon CLC 1150 Color Copier
Error 0070
I don't see this error in the book. Are you sure of the model CLC-1120 )?
Jan 29, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1180 Copier / Digital Colour Printer Print Spreads
hi im jules_09 service manual are not given to clients because its a secret company keeps only there service enginer can avail to it.but if the colore spreads out check your developer or the entrance of each developer somtimes it the developer leak out specially if the developer seal is deffective
Oct 03, 2007 | Canon CLC 1120 Color Copier
128 people viewed this question
jasbo
jasbo
