Question about Frigidaire AEQ7000ES Dryer
I have a frigidaire affinity dryer that won't heat up. Everything else works as advertised. It will run for about 20 minutes, stop, and sometimes display an AD or ADD display?
  • 25 Answers
CHECK THE THERMAL FUSE, OR THE COILS LOCATED OT TOP OF THE GAS VALVE CHANGE IT
Posted on Nov 11, 2010
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Dryer wont heat up
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Affinity aeq7000eg0 no heat stops after 20 minutes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 01, 2011 | Frigidaire Affinity AEQ6000WH Dryer
My frigidaire affinity dryer is not heating up but still works what is wrong?
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryers Logo
232 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
