Question about Ingersoll Rand SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical
Standing in front of the SS5L5 pump pulley, looking at it,should it turn CW or CCW?
    President:
  • Ingersoll Master
  • 1,388 Answers
Easy to tell what direction pump turns. Look at pump pulley and notice and fan shape of the spokes. The pulley blows air across the pump. Most pumps turn ccw, however verify by looking at fan. Good luck
Posted on Nov 11, 2010
Looking rearward towards front of engine from in front of radiator, which way, CW or CCW, does 87Ford Ranger2.9L crankshaft (fan & pump) turn?
fan clutches are Left hand thread as they tighten up when the engine is running. If they were right hand thread then when the fan is working they would come loose off the shaft
In short undoing then actually tightens them
Jan 11, 2015 | Cars & Trucks
Maytag bravo washer model number MTW6700tQ0 wont finish spinning please help!!
Hello c bellone,
If you rotate the clutch pulley by hand CW the tumblers should rotate in the wash basket.If you rotate the clutch pulley CCW the tumblers will rotate until the clutch spring comes under tension then the wash basket will begin to turn CCW and the tumblers will stop rotating because the transmission rotates with the wash basket. Do you have this action?
The clutch has been an issue for many are you taking dc or UC errors to the display?This clutch incorporates a Drawn Cup Roller clutch bearing (one way clutch bearing) designed to rotate freely CW and lock up CCW to rotate the spinner shaft in spin cycle rotating the wash basket/transmission CCW.You are halfway thru the clutch removal process, I would drop the clutch out and inspect the roller clutches, clean them up with WD-40 and some light bearing grease.If they are rusted up beyond clean up and or the clutch spring is broken as in this post you will have to replace the clutch.You will know what you are up against once the clutch is out and opened up for inspection.
Here is the process I use for clutch removal;
Access and remove the Clutch for maintenance
Disconnect 120VAC power cord.
Nov 27, 2012 | Maytag Bravos MTW6700TQ 4.6 Cu. Ft. Top...
How do i remove the fan and pulley on a 1987 ford ranger 2.9 v-6?
The question is: How remove clutch in order to remove fan mounted on its engine-side face.
  • Generally, the clutch drive half shaft must be uncoupled from coolant pump (impeller drive) half shaft using special wrench kit available as loaner from AutoZone (free with $79 approx deposit).
  • Best done after shroud & radiator remove after coolant drained.
  1. Uncouple coolant pump and fan clutch drive shaft(s) as follows:
    1. span across combo-pulley-sheaves-unit mounting bolt heads with large tool kit wrench, and
    2. span inline clutch coupling nut with small tool kit wrench. Then,
    3. turn small wrench (and coupling nut) CW while resisting with large wrench (CCW) to turn coupling nut until disengaged from coolant pump drive shaft.
  2. Remove fan/clutch assembly.
  3. Note direction of mounted fan hub and fan blades orientation to ensure proper re-assembly.
  4. On rear of clutch assy, remove 4 bolts to disengage and remove fan.
  5. Assemble new fan to clutch (or, preferably, new clutch and new fan) using new bolts and washers provided with fan.
  6. Couple fan-clutch assy to coolant pump drive shaft as per opposite of uncoupling step 1, above. (Turn inline nut CCW to tighten...30 ft-lb.
  7. Check that fan can be hand turned...CW.)
  8. Rest shroud over and onto fan.
  9. Replace radiator; remount shroud; reclamp hoses, and refill and air purge cooling system.
Aug 12, 2012 | 1987 Ford Ranger
The belt fell off, looked worn so purchased a new one and put it on (very tight!) Started machine, and belt new belt fell off. Pls help.
Can you confirm your model number? FAV6800A or FAV9800A?
If it's one of those models with 120VAC power cord removed from the service outlet and the front cover removed. See if you can rotate the Clutch Pulley CW the wash agitate direction and then CCW the Spin direction. The Clutch Pulley is the large pulley in the center of the washer. We are looking to see if the drive system is seized.
After the drive belt replacement was there any belt screech when you powered up the machine and selected a Wash or Spin Only Cycle?
Feb 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag fav6800aww washer (transmission) problems
James,
“”All looked well but when the motor switched directions it locked up and started squeeling real loud and the belt was going around clutch but clutch didnt move.“”
Was this during the water fill cycle the machine? The Control Board will signal the Motor Controller to spin Motor/wash basket 50RPM in the CCW direction during water fill of the Cycle selected. This is the Spin direction of the wash basket during all spin cycles. If you can observe with the front cover off. Don’t raise the washer top from the base to far or you will spray water around the machine.
You can empty the wash tub with excess water by going into Service Mode and turning on the Drain Pump;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
What are the 1st two digits of your Serial Number that is your series number found here;
Did your old clutch pulley use the Upper One-Way Roller Clutches bearing ring?
With the belt off the can you rotate the Clutch Pulley by hand CW direction the Wash/Agitate direction tumblers will turn. Then rotate the Clutch Pulley in the CCW direction the Spin Cycle direction. After the Clutch Pulley is rotated a few turns the Large Wrap spring in the Clutch Pulley will come under tension and the Wash Basket will rotate CCW. Someone will have to verify that for you while you are on your knees.
I'm wondering if you have the Clutch Pulley seated properly. Sorry you wasted money on the Front Struts. Did you follow my Clutch Fix post for the Clutch maintenance/replacement?
Let’s start there and try to determine if the Clutch Pulley will turn both directions by hand. If it won’t I would reseat the Clutch Pulley and try again.
See my Clutch Fix post for reseating the Clutch Pulley and the SM on page 47. Note the 1/16-1/8" gap between the Pulley face and shaft end.
The coins are normal for us folks that don’t check pockets….:)
It’s difficult to rotate by hand the pinion gears of the tranny that drive the tumblers. I have not seen any transmission lock up to date but that is possible.
Let me know if I can help. I know you have the SM the parts view is handyif you don have Sears Parts Direct
Also how much rust on the old Clutch Pulley? You may have a slight tub seal leak and I can help you with that.
Rich
Jul 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune FAV6800AWQ Serial Number
Fireman,
Excellent info wish all post would start off like this. The first two digits of the s/n are your series number a Series 16 machine I’m an owner no expert and will try to help.
I assume you have the Service Manual but just in case.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
“”I can grab the drive belt and effortlessly move it back and forth-pulley spins and motor spins--Should it move like this?””
There should be slight resistance.
With the front cover off and be careful of the rotating drive belt can you start a Spin Only cycle?
Do you see the Motor rotate the Clutch Pulley assembly CCW? If so the wash basket should spin CCW just raise the washer top and verify the CCW/Spin rotation.
If that works again with the front cover off start a Quick Wash cycle min Soil/Spin settings and observe as the washer. As it fills the wash basket will be rotating CCW don’t raise the washer top to high or you will spray water around.
After the water fill the washer will start to Wash/Agitate. The Motor will rotate the Clutch Pulley CW and the Tumblers will rotate. Do you see this action.
You can go into Service Mode with this procedure and dump the wash water if the cycle fails with this procedure.
Thank you again for the Model number and Serial number…. other readers this is how you post an issue.
Waiting for your feedback………Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I just replaced (new) the clutch on my FAV9800AWW, and machine goes through most of regular cycle, but at some point (reverse or tumble?), it tries to do something between the motor and clutch and the belt...
Hey gunsmoke55,
Let’s collect some info. and I will try to help. I own the FAV6800A the LED flavor of the machine and as you can tell from my nick name I DIY all repairs on the machine.
1. Did your FAV9800A signal an unbalance statement to the display to trigger the clutch replacement?
2. How badly rusted up was the One-Way Roller clutches bearing? Did you follow my clutch maintenance/repair post to replace your new clutch? Clutch Fix Post .
3. When you removed the original clutch did your series of the machine use the Upper One-Way Roller clutches bearing ring? From pulling info. from other FAV6800A owners I have been able to confirm series 10 and 11 used the Upper One-Way Roller clutches bearing ring. Info from FAV9800A owners is very lean. What is your series of machine (the first two digits of your serial number) and did it use the Upper One-Way Roller clutches bearing ring?
4. You should be able to rotate the wash basket with one finger CCW with very little resistance. Try that and let me know if the wash basket will rotate CCW with one finger . The wash basket must not rotate CW by hand. With the front cover removed (pull the 120VAC power cord) you should be able to rotate the Clutch Pulley CCW and CW with light resistance.
“”I just replaced (new) the clutch on my FAV9800AWW, and machine goes through most of regular cycle, but at some point (reverse or tumble?), it tries to do something between the motor and clutch and the belt just squeals very loudly and burns. Ideas? SW””
If you machine used the Upper One-Way Roller clutches bearing ring it may not be seated in the wash tub base properly. It is a very tricky fitment process to re-install it and the Clutch Pulley assembly correctly. Let me know what you find and we will go from there.
Some insight into normal operation of the machine you may be aware of this; In the wash/agitate cycle the Control Board signals the Motor Control board to power the Motor CW turning the Clutch Pulley CW driving the agitator shaft which drives the transmission to rotate the tumblers only.
In a Spin Only cycle or the Spin Cycle of a Wash Cycle the Control Board signals the Motor Control board to power the Motor CCW turning the Clutch Pulley CCW. The One-Way Roller clutches lock up solid driving the Spinner assembly CCW spinning the wash basket CCW. When the One-Way Roller clutches do not lock up rock solid and slip you get tumbler movement as the wash basket begins to spin up. This causes the wash basket load to go off balance and if the TDS is working properly it’s signal input to the Control Board exceeds design limits of Outer Tub movement and the Control Board fails the Spin Cycle wit a dC or uC unbalance error or in your case an unbalance statement to the LCD display.
Also during the initial water fill cycle of the wash cycle the Control Board will signal the Motor Control Board to power the wash basket CCW slow RPM. I believe the Maytag design team did this to wet the wash basket load on initial water fill…..Rich 5a647fe.jpg
Feb 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
1994 dodge ram 1500 water pump. metal tube on top right (looking head on at front of enging) this pipe is leaking where it goes into the pump. is this a screw (treaded) tube or something else?
It could be either threaded or press fit depending on who made the pump for Dodge. Drain the system and attempt to remove the pipe by turning it CCW. If it is a press fit, it shouldn't turn at all and you may need to replace the entire pump for repair. If it turns, pull it out and line the threads with several turns of teflon tape wound in a CW directon (looking at the thread end). Make sure the casting is not cracked at the hole where the pipe fits.
Aug 25, 2009 | 1999 Dodge Ram
Maytag neptune washer model fav6800aww wont finish spin cycle
Hello c bellone,
If you rotate the clutch pulley by hand CW the tumblers should rotate in the wash basket. If you rotate the clutch pulley CCW the tumblers will rotate until the clutch spring comes under tension then the wash basket will begin to turn CCW and the tumblers will stop rotating because the transmission rotates with the wash basket. Do you have this action?
The clutch has been an issue for many are you taking dc or UC errors to the display? This clutch incorporates a Drawn Cup Roller clutch bearing (one way clutch bearing) designed to rotate freely CW and lock up CCW to rotate the spinner shaft in spin cycle rotating the wash basket/transmission CCW. You are halfway thru the clutch removal process, I would drop the clutch out and inspect the roller clutches, clean them up with WD-40 and some light bearing grease. If they are rusted up beyond clean up and or the clutch spring is broken as in this post you will have to replace the clutch. You will know what you are up against once the clutch is out and opened up for inspection.
The
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Remove the front panel see page 41.
Tools required;
3/8 inch socket and socket wrench to remove clutch pulley bolt. Page 47 of the SM
1/2 inch socket or wrench to loosen Drive Motor tension bolt.
5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the SM.
1. Lean the washer back and blocked in that position for a better reach angle. Rotate 3/8” clutch Pulley Bolt CW to remove clutch bolt.
2. Follow SM page 46 & 47 to remove clutch pulley.
3. Remove 4 screws holding plastic cover on clutch, inspect clutch spring to make sure it is not broken. Inspect roller bearings clean up with WD-40 and re-lube with bearing grease.
4. Replace white bearing plate into clutch pulley hub, insure key slot slips into clutch Spring pin in clutch hub.
5. Replace Clutch plastic cover with 4 screws.
6. Reseat clutch on spinner shaft and rock back and forth while lifting clutch with upward pressure to reseat clutch. When seated properly you will feel a 1/16-1/8" gap between the Pulley face and shaft end as mentioned and shown on page 47 of the SM. On reinstallation, tighten Clutch Pulley bolt CCW to 96” pounds 8’ foot pounds (Snug no torque wrench required).
7. Do a quick wash and make sure clutch runs true with no wobble or clicking sound. If the clutch has not been seated properly it will spin off. If this happens go to page 16 of the SM Board Output Test and turn on Drain Pump in Service Mode to pump out excess water.
8. Repeat steps 6&7 if the clutch has excessive noise or spins off.
My clutch open up for clean up.
Apr 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Ingersoll Rand  SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical  Logo
170 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
