Question about Acer Extensa 4620 Notebook
Acer Extensa 4620-4605. Hidden hard drive? What is it for and how do I find it?
    Genius:
  • 1,035 Answers
Welcome and thank you for using fixya.
Hidden harddrive or partition are usually alloted for factory restore software.This software will restore your computer to original factory state without using the recovery disk. In order for you to find if you hve one in your computer. All you need to is to go to computer management then go to disk management. The easiest way to get there is by clicking the start menu then type in under start search or run bar this compmgmt.msc then press enter.
All the best!
Posted on Nov 11, 2010
Testimonial: "Fast and straight to it!"
Is Acer Extensa 4620 Notebook support 1tb hard disk
If it is Win7 and is partitioned to two 500Gb or three 330Gb drives, I see no reason why not but it will run very slowly!
Feb 01, 2014 | Acer Extensa 4620 Notebook
Will acer extensa 5230E reinstallation cds contain windows
A driver restore disk works with a windows disk to return your Acer Extensa 5230E Windows 7 back to the original factory setup.
Once windows has installed you put this disk into the drive as soon as windows gives you a found new hardware dialog box. Once inserted the Acer Extensa 5230E Windows 7 will automatically find all the drivers and also install most of the original factory software. BEWARE OF GENERIC DISKS ! All Drivers and factory software are operating system specific so you must have the correct software and drivers for your Acer Extensa 5230EWindows 7. Some of the drivers you would find on this Acer Extensa 5230E Windows 7 Restore Disk are listed below. Not all will be applicable to your system as this list is for information only for Acer Extensa 5230E Windows 7 Restore Disk.
THIS DISK DOES NOT CONTAIN AN OPERATING SYSTEM!
YOU WILL NEED TO INSTAL Windows 7 FIRST OR USE AN EXISTING INSTALL.
Hope this helps
Dec 18, 2012 | Hitachi Travelstar 5K320 HTS543232L9A300...
Download operating system for acer extenser 5220 laptob
If you don't have disks, it may be possible that a factory default image can be restored from a hidden partition on the Extensa 5220 hard disk drive. On powering up, press the Alt key and the F10 key together (at the same time) repeatedly and after a minute or so you should start Acer eRecovery Management. Then, follow the on screen directions to restore the factory default image.
Mar 18, 2011 | Computers & Internet
Where can i buy a recovery CD for my Acer Extensa
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press <F2> during POST.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 10 GB in a hidden partition on
your hard disk.
Apr 09, 2010 | Acer Extensa 4620 Notebook
My acer Extensa 4420 not booting up
dell inspiron 6000 pc note book or
acer Extensa 4420 which one ? either or sounds like hard drive is shorting out and you need to change it  lala linda
Dec 23, 2009 | Dell Inspiron 6000 Notebook
Acer Extensa 4420 suddenly won't boot. Don't have recoery disks. Can I download them from internet, burn to disks on another computer, and then use them on the Acer?
Modern PCs and laptops have the operating system tucked away on a hidden part of the hard drive. You will have to read the manual or - better - get the manufacturers on the phone to find out how to recover or reinstall the system.
Jul 08, 2009 | Acer Extensa 4620 Notebook
Acer extensa 4630z will not boot up. System restore will not work. how can I reformat hard drive?
If you want to go down the route of reinstalling windows, you will need the windows disk which came with the laptop.
Insert the Windows CD that came with your PC, and reboot your system. If you didn't receive a Windows disc with your machine, the files you need are sitting in a hidden partition on your hard drive. To access them, press the keys indicated on your screen when you reboot, but before Windows loads.
If it gives you the option to boot from the CD, make sure to do this.
Once you have got to this stage you follow the steps through. Delete all the partitions and the format the hard drive. You will then be able to do a clean install of windows.
Best of luck
Jul 07, 2009 | Acer Computers & Internet
Weird whirring, no boot, corrupt recovery partition
IT SOUNDS LIKE THE HARD DRIVE IS GOING ....DO YOU HAVE ANOTHER SYSTEM THAT THIS HARD DRIVE COULD BE CONNECTED TO ? THIS WOULD BE HELPFUL TO UNDERSTAND IF IT'S THE ACTUAL HARD DRIVE GOING OR YOUR FANS. PLEASE ADVISE
Jun 02, 2009 | Acer Extensa 5620 Notebook PC
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Acer Extensa 4620 Notebook Logo
477 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
