Question about GE JV347H Kitchen Hood
GE JV347H1WW kitchen hood. The fan rattles when it's ON. What's an easy fix to the problem?
4 Suggested Answers
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
  • 72 Answers
SOURCE: Whirlpool Gold Stainless Steel Kitchen Hood Fan not working
Try cheking the fuse first.
Posted on Dec 28, 2009
  • 3368 Answers
SOURCE: GE top freezer refrigerator fan rattles constantly
It is mounted properly, it is probably a bad bearing in the fan motor and/or the blade is loose on the shaft. Replace the motor.
Good Luck,
Gil
Posted on Mar 01, 2010
Good Luck,
Gil
Feb 28, 2010 | GE PTS25SHS Stainless Steel Top Freezer...
Where can I find the internal fuse on the GE Monogram Hood model ZV950SDSS?
There are (2) inline 5A - 125V fuses under the top fan/duct cover. They are located on the left side (as facing the unit) in a plastic junction box. Four Phillips head screws hold the cover on.
Dec 30, 2009 | GE ZV950SDSS Kitchen Hood
Convection oven fan rattles when it is starting up after the oven has reached its desired temperature. The fan motor has been replaced once but it didn't fix the problem.
Check the shield in front ok the fan. It may have become distorted with heat and is now touching on the fan when the oven reaches temperature.
Nov 22, 2009 | GE Cafe CGS980S Kitchen Range
The fan makes a very loud noise
the fan blade may be loose on the motor shaft there is a set screw on the blade center you can tighten (it needs to be very snug)
Aug 22, 2009 | Kenmore 51841 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Oct 21, 2008 | Viking VWH3048 Kitchen Hood
GE JV347H Kitchen Hood Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
