Question about Rheem EcoSense by 7.4 GPM Tankless Water Heater Natural Gas High Altitude
C2 11 error code. what is the problem? - Rheem EcoSense by 7.4 GPM Tankless Water Heater Natural Gas High Altitude
  • 12,061 Answers
I have read where c211 code is a gas burner flow issue. The fix has been to accees the burner after turning EVERYTHING on it off, (water, gas, electricity) and cleaning the burner of any build up. Apparently the burner is accessible by removing 20 plus screws.
Posted on Nov 11, 2010
Manual
Copy following link for Rheem tankless troubleshoot resources, including error codes, manuals, and general information for maintaining your tankless computer that heats water.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Multiple error codes can indicate failed PC board. Rheem will send PC board... so your computer-that-heats-water might have failed motherboard.
Continual maintenance can help avoid common error codes, but some problems are insoluble and chronic.
Jul 16, 2013 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
I have a poloma model/ pt62-42pvn its flashing error code c4 76 i have had no hot water for six days now need help
1) Before calling service technician who can test parts, open following link for Rheem resources including error codes, Rheem chat and phone number, possible manual:
If local technician cannot solve problem, Rheem can probably recommend a person.
2) Error codes are start-point for troubleshooting.
3) Multiple error codes can indicate PC board failure.
If your computer motherboard fails, most people feel the computer is compromised even after motherboard replacement.
4) Error code C7-76 is communication error with remote, and can include bad remote, bad wire to remote, loose wire, or bad PC board.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
5) Error C4-13 can include part failure, vent problem, oxygen depletion, and can also include PC board failure.
http://waterheatertimer.org/pdf/Error-code-13.pdf
6) Tankless routine maintenance manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
7) Some posts about tankless concede that qualified technician was unable to repair unit.
Solve most tankless problems yourself, same day, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 08, 2011 | Rheem Paloma Tankless Water Heaters...
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
Code c4-13
Before calling service technician, open following link for Rheem troubleshoot resources including error codes, Rheem chat, and possible manual:
Error code C4 13 is bad oxygen sensor, inadequate incoming air supply, or bad venting. Also bad PC board, or internal wiring, or temperature set too high, damaged burner parts.
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Tankless require yearly maintenance to combustion chamber and burner parts.
Prescribed maintenance can correct some of the issues in error code 13.
Jun 25, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
C4,76 what is it?
Before calling service technician, open following link for Rheen troubleshooting resources and possible error code help plus link to Rheem chat:
Typically, error codes are start-point for troubleshooting.
Error 76 is communication fault with remote control, which can be bad remote, bad wire, bad wiring connection, or bad part inside tankless.
C4 is oxygen sensor problem or bad venting.
More than 1 error code, or mixed error codes can indicate problem such as bad PC board -or- PCB.
Jun 23, 2011 | Rheem Tankless Hot Water Heater...
Rheem EcoSense by  7.4 GPM Tankless Water Heater Natural Gas High Altitude Logo
867 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
