Question about Whirlpool Ovens
Have a whirlpool stove model number rf262lxsb. stovetop works but oven wont turn on.
  • 65 Answers
SOURCE: electric surge turned off the clock,oven but the stove top works
do you have both legs of the 220v? on the board see if you have 120v at L1 and L2. if you do then you have a bad board.
Posted on Feb 19, 2008
SOURCE: oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Posted on Dec 21, 2008
SOURCE: whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Posted on Dec 25, 2009
heatman101
  • 43501 Answers
SOURCE: oven doesn't heat up
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 06, 2010
tbirdfan1
  • 3051 Answers
SOURCE: Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jul 25, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool owners manual gas stove W10198615D
Most Whirlpool model numbers start with two or three letters and have another two letters later in the number. W10198615D may be your serial number or a Lowe's product number, not the Whirlpool model number.
Usually though the model number and serial number aren't on the back of the stove. The plaque with this data is on the rim of the oven behind the warming or storage drawer.
The manuals that are available are here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
Please recheck your model number and post a comment with the correct model number. I'll be glad to try to get the correct manual for you.
I wish that I could be of more help right now.
Dec 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
F19 error code on lg double oven
had F19 error code on lower oven, F9 on upper. Pulled stove out and turned the regulator switch ON. Worked instantly. I thought I had the regulator on because the stovetop worked. The stovetop regulator is separate from the main regulator!!
Jun 22, 2011 | LG LWD3081ST Electric Double Oven
My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
To lock/unlock the controls: Turn all surface burners off.
Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
Feb 11, 2011 | Whirlpool Ovens
Cant get oven to turn on. the only thing that works is the stove top n have to light it my self. My electical screen wont turn on which controls my oven
Check and see if the stove is plugged in. I suspect your DSI module has failed.
All these stoves ain't the same nor do they even work on the same principle. I am guessing from the picture you have a DSI system. For a more precise answer always post a mdle number. Most model numbers are posted on the oven frame of the lower drawer.
Here is your DSI service Manual
Dec 21, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven went last night after tripping fuse when flipped back on stovetop works but oven doesn't how do i fix this issue
there are often fuses on the oven somewhere.if u can type your stove model into google and get schematics for your stove it should show u where they are on your stove. hope this helps
Nov 11, 2010 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
89 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
