I have a Ruud Achiever ii UALA-030JAS, I want to now, how many tons is it?
  • 43,501 Answers
In the model number the 030 stands for a nominal 30,000 btu output....at 12,000 BTU per ton that translates to approx. 2.5 tons of air conditioning with a properly matched coil.
heatman101
Posted on Nov 11, 2010
Testimonial: "Thank you"
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
I have a ruud achiever 10 model upgc-030jas and a high eletric bi
I'm using a calculation of VxA=W. Assuming your system is 240 volts and total amperage of system with 15 amps, I come up with 3600 watts or 3.2KW. Because the outdoor temp was above 35 deg F, the electric heaters probably did not cyle on to frequently if at all. Your calculation sounds reasonable to me. To determine exactly how many KW your system is using, you will need to determine exactly how many volts and amps your unit is running at...both indoor and outdoor units if this is a split system.
I've included a link to a website that helps the homeowner to determine the KWh.
I hope you found this helpful and good luck in your endeavor! :-)
http://www.sci-ed-ga.org/modules/k6/elec/elec.html
Feb 26, 2010 | Heating & Cooling
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Wiring schematic - RUUD
Schematic
All Projects with Photo Preview Browse over 10000 circuits. Now! www.ElectronicsInfoline.com
Jan 02, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
