Question about Zojirushi CD-LCC30 Electric Kettle
On my Zojirushi CD-LCC30 when I press the unlock and then dispense buttons I hear the pump "whirring" but nothing comes out. I have had my zoji for about 3 years and it has worked fine until now. This malfunctioning happened after I ran the descaler. I have since emptied out, refilled, unplugged, etc. Any thoughts?
  • apin May 20, 2012
    I have the same problem. Any solution?
I called 1-800-733-6270 (taken from http://www.zojirushi.com/servicesupport/manuals/manual_pdf/cd_lcc.pdf). The rep was very helpful. She suggested that there was probably residue stuck in the tubes. She suggested that I use citric acid solution and put it through a cleaning cycle. After the cleaning cycle, do not pour out the water immediately. Instead, dispense the water through the Dispense button, to clear out the tubes. It worked. I had just gone through a cleaning cycle before this problem happened to me, and gotten rid of big chunks of "crud" (especially the build-up around the filter).
Posted on May 21, 2012
The water will not dispense and the ice cubes will not come out. I noticed on the front panel that IWD is "off" and that it shows "lock"ed at the bottom of the screen. I know that the...
Press Freezer and Super at the same time for 5 seconds to turn Ice & Water Dispenser on. This will remove "IWD Off" indicator. If it is locked, press the Alarm/Lock button for 5 seconds to unlock it.
Feb 17, 2011 | Bosch B22CS50SNS Side by Side Refrigerator
Recently bought a house that has system CVA615. Hasn't been used a dozen times they said - so I cleaned per instructions. It now says "hot waster - expel air". Have done everything book said...
When selecting "Hot Water," can you hear a pump working (usually a strong buzzing sound)? If you do, then water path may be blocked or pump itself is jammed. A jammed water pump still makes buzzing sound. May be stuck from not using, for long period of time. Especially, in hard water areas.
Nov 04, 2010 | Miele Coffee System
Water at door stopped working. water still comes to ice maker. no damage to electronics panel. Ice dispenser, whole and crushed works fine. is there a relay in the water circuit that fails? Or, is a...
I have the exact same problem. Ice maker works but nothing at the water dispenser. The light come on when I press the lever and I hear a click. But nothing like water "trying" to be pumped. I am nervous it is more than just a frozen water line. Anyone else have this problem or a solution?
Dec 09, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Water feature does not work
Unplug the female connector on tear of refrigerator on the side that feed the dispenser control. With a voltage meter place the 2 probes while some presses the dispense water control. You should get 120 volts there when the dispenser switch. Thanks Sea Breeze
Nov 16, 2009 | GE GSS25SGPSS Side by Side Refrigerator
How do I clean the Hot Water Dispenser?
I have zojirushi 4L (model: CD-LCC). I noticed that the bottom of the pot have some stain which are looked like "corrosion". What should I do? How to remove it? Please help.
Thank you
Nov 01, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
Zojirushi electric dispensing pot
Got greasy white stuff floating inside the kettle, any idea where this comes from? And how to eliminate it besides getting a new one. This unit is over 5 years old. Thanks.
Oct 18, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
VM9511TS wont eject
Does it make noises like it's trying to eject? Like whirring motors?
Sep 10, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Zojirushi CD-LCC30 Electric Kettle Logo
362 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
