Question about Leupold ® Rifleman® 3-9x50 mm Scope
I have about a 1989 model Leupold 3x9 Var X and lost the users manual- it is shooting about 2-3 inches to the right at 60 yards- Can you tell me which way (lft or right?) and how much- I assume I should adjust it right, but I don't know how far-thanks- John G
  • 2,100 Answers
You have a number or a fraction on the inside of the windage cap, or you should, it will say something like 1/4 or 1/2? That will tell you how many fractions your scope moves with each click, at 100 yards. Anyway, there is also a left and right direction on the scope, you want your scope to go in the direction of your bullet miss, this will pull the barrel over to the center, again, it is supposed to. If you have run out of clicks, you will need to shim your scope. So, on the 1/4 inch at 100 yards, you will want to move the dial, 8 to 12 clicks to the right. Shoot it again, if it went the wrong way, you know what to do. If it didn't move at all, try this.... If it is a bolt action rifle, pull the bolt out, mount the rifle in a cardboard box with v grooves cut in it so it will cradle and not move, or a vise, sight down the barrel at a target at 100 yards, then peek down the scope, it should be right on the target, if not move the cross hairs till it aligns, check the barrel again, make sure it didn't move, then peek through the scope again, if it is the same, it will be on paper at 100 yards, if it is not a bolt action, the only other rifle you can d it with is an AR type rifle. This is a military trick, not something I dreamed up, it works. Check it out.
Posted on Nov 11, 2010
How to covert meter to yard on leupold pincaddie
One metre is the metric equivalent of one yard three inches.
Apr 26, 2016 | Leupold PinCaddie Rangefinder
Can you explain to me about moas? i got this new p4 and im trying to learn how to use it can you tell me? and do i have to site it in at 100 yards first?
If you are going to attempt to sight in your rifle scope for hunting or just shooting, you will need a basic understanding of what a Minute of Angle is.
Think of a circle as it is divided into 360 degrees.
Each degree is divided into 60 minutes.
Each minute is divided into 60 seconds, but we don't use that for ballistics, seconds of angle are just used in machine shops and in rocket science.
Minute of Angle
1 MOA = 1/60th of a degree
1 MOA = 1.047 inches at 100 yards
Most accurate long range scopes are set in quarter clicks (4 clicks = 1 MOA) or eighth clicks (8 clicks = 1 MOA) but less accurate short range scopes are sometimes set in half MOA clicks (2 clicks = 1 MOA)? which to me is the opposite as it should be.
For a .308 the difference between shooting at 100 yards and at 500 yards is about 11 MOA. That adjustment with a scope using eighth clicks is 88 clicks.
Most accuracy testing is done at 100 yards, because it makes the math easier, and it is close enough to see the bullet holes through a spotting scope.
Folks usually say that 1 MOA is equal to 1 inch at 100 yards, which is almost exactly correct, as 1 MOA is only slightly more than 1 inch at 100 yards. But for what we are doing it is close enough. Now think it on out to 300 yards, 1 MOA is then equal to 3 inches. So if your shots are 1 inch off to the left at 100 yards; out at 300 yards, you will be off to the left 4 inches. Clear as mud? Hope this helps.
Jan 04, 2011 | NcStar 3-12x50e Rifle Scope Illuminated...
I have a bigcat and it will not shoot a gooup
I have one of the BIG CAT rifles and can shoot under 1" groups. First Check the gun and be sure it is tight in the stock. I had to remove the front screws and pot nylon washers under them to get the stock tight!
Second. I could shoot decent groups and the they would move! I replaced the scope mount with a better quality better fitting scope mount. Be sure it has the stop pin that fits in the hole in the top of the rifle or they will move to the back and never be stable.
Third. I replaced the Gamo scope with a Leupold 3X9 varix 2. I am not sure about the Gamo scope but while I was mounting a scope I decided to try the Leupold.
I have shot some 5 shot groups from a good rest that was less than 1/2". The factory scope mounts looked like a bad fit on the groves of the rifle and looked canted.
The best pellets I found are the PREMIER HOLLOW POINT and some of the worse were the GAMO FLATPOINT!
Dec 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Hello, I have a Bushnell sportsman 3x9 mounted on a 22. I bought it new last year, but only took it to the range last week. I can't get the left/right cross hairs to move enough. At 25 yards, it shoots 9...
Start buy loosening the scope in the mounts. Loosen the front first to see if it is in a bind (left/right). Tighten it back down but not completely. Loosen the rear looking for some movement or popping sound. If you see a movement or notice some odd thing. check the mounting slots for dirt or dings that may cause an offset to the mount. If all is well. Go and start and zero for 13 - 15 yards. you want to be 1 1/2 inch hi. Now after each shot rap the scope with a screw driver handle or something solid, just to give the scope a shock not hard enough to bend it or dent it but shock it. Large scopes are meant for larger shock than a 22 produces, rapping the scope will help move the cross hairs and settle them in place. Hope this Fixya up. If it does help, please leave a testimonial. Thank you for using Fixya.
Dec 11, 2010 | Bushnell Sportsman 3-9X32 Silver Gun Scope...
Leupold VX II 3x9x50mm scope on a rem. 270. One year old. Worked fine last year. Sighted in last week at range. Windage was dead on. Wanted to move up 1 inch in hieght at 25 yards. Tried to adjust hieght...
16 clicks is about 4" at 100 yards not 25. did you try shooting it at 100 yards? remember the scope is mounted at least an inch and probably higher than that above the barrel. at close range you will always hit low with a scope because the bullet has to climb at least an inch or more before it will be right on at 25 yards. if it is dead on at 25 it should hit way high at 100. (or the scope/ mounts are bad).
Nov 05, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
This is my first Leupold scope, I don't understand the friction adjustments 1/2 MOA dials, I need to adjust 3 inches up and 1and 1/2 to the right, I have moved the dials in the direction indicated to no...
minute of angle is not the same as 1/4" per click at 100 yards. if it doesn't click something is wrong. i would call leupold and probably try to get a replacement from where you bought it. moa is an angle value not an inch value.
Oct 23, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
What's one click wont mean at 50 yards
One click at 100 yards = 1/4 inch movement of the bullet
One click at 50 yards = 1/8 inch movement of the bullet
etc.
Sep 17, 2010 | Leupold 3 - 9 x 40mm VX-II Series...
Scope wont shoot good groups
That can get expensive, I had the same problem, bought a Bushnell scope and it went everywhere but on the target, couldn't hold it steady, with my win mod 70 in 308 with heavy barrel, I said that's it, I went and bought a Leupold, no problems since. I don't know what was wrong with the Bushnell, just couldn't handle the blast I guess. I put he Bushnell on my bolt action 223 and haven't had a problem with it, but always expect one because of what happened before. I don't remember the model number, but it was a 3x9. Hope this helps.
Jun 20, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
I have a Leupold 3x9 VX II I'm finding that both windage and elevation adjustment screws are very difficult to turn. Is there a special tool I should be using for this or should I just be careful with a...
Leupold has a very good service policy, They'll repair it no matter what.
Send it in to them and let the experts fix it.
Here's their contact info:
1-800-LEUPOLD
Hope this helps, Mark the Gunsmith
Dec 06, 2009 | Optics
I have just purchased a 4x16x40 center point scope to replace a 3x9 weaver on a 50 cal muzzel loader @ 80 yards it was dead on my new scope shoots 6 inches left of center @ 80 yards and i am out of right...
yes it can be its not a lot out realy,, you could try swoping round the rear mount this may help but if not use a bit of 35mm film to shim the scope out
ps,, how long do you need to wate to see if you hit any thing ??? ha ha ha,,fogy "A" grate fun had by all!
Nov 12, 2009 | Centerpoint Technologies CenterPoint...
Leupold ® Rifleman® 3-9x50 mm Scope Logo
320 people viewed this question
Top Leupold Optics Experts
George Merkley
George Merkley
ray gallant
Are you a Leupold Optic Expert? Answer questions, earn points and help others
