Question about Dell W2600 26 in. LCD Television
Television has sound but a black screen - Dell W2600 26 in. LCD Television
  • 11,361 Answers
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=dell+w2600
It mayhave 24vdc power supply problem, backlight inverter board, main board problem, T-CON board problem.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 11, 2010
  • Dell Master
  • 8,457 Answers
Tv turn on now,have picture flashes few sec.than died and have only sound left only?Yes,than the long board call the LCD inverter board is dead.The Long LCD inverter board help the tv LCD screen panel have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long refurbish LCD inverter board for the replacement.
I turned on my tv the picture flashes on and off few times then black screen.It does have sound tho.
We had a TV repair guy come out as our television was doing the same thing black screen with sound. Well he told us unless we want to replace the screen the television was done. Best of luck we just bought a new one.
Jun 28, 2015 | Samsung Televison & Video
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
Screen black still has sound
Try in a very dark room with set on to look close at screen and or use a flashlight to see if faint images can be seen or not......
Oct 30, 2012 | Proscan 47 in. Diagonal Class LCD Full HD...
Soft "Pop", Then Black Screen. Sound is OK.
First check the inverter for any burst capacitors and the display boards.
Aug 28, 2012 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
My tv has sound but the screen is black. At times
Ur LCD inverter board is dead.Must replaced the board.Usally a long board.
Jan 05, 2010 | Olevia LT27HVX 27 in. LCD Television
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Dell W2600 26 in. LCD Television Logo
102 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
