Question about Broan-NuTone VX475 Bagged Central System Vacuum
Is there any known do-it-yourself fix for the nutone vx-550 overheating problem?
    Novelist:
  • 147 Answers
There is a way to do it, yes. However, are you sure that the PC board inside is not what is causing the problem?? I mean, are the lights on and function normally when you turn the switch on or off??
If so you can proceed to bypass the two thermal cut offs located on the field coil on both sides of your motor inside. Yes, it can be done without taking the motor apart.
Also, move the other thermal next to the motor and attach it to the housing near the back of the machine. DO NOT remove it unless you absolutely need to. IE test the unit and let it run for approx 20-25 mins. if it does not shut off there is no problem with the last thermal cut off. If it shuts down within 5 mins, take it out too. It could be faulty now.
Good luck,
Mark
Posted on Nov 11, 2010
My VX550CC also shuts down after about 15-20 minutes. My problem is that I can't find my sales receipt. Nutone told me after contacting them several times that they will not honor their warranty unless I...
Some People Hu...........Make sure that all filters are clean if need be renew..Sounds like overheating fault resulting in Thermal cut out operating....Good luck
Feb 19, 2011 | Broan-NuTone VX475 Bagged Central System...
Nutone cv750 problem
I doubt that's an electrical breaker - because it wouldn't take 10 minutes to flip, it would happen almost immediately. It must be the heat breaker. There are two reasons your vacuum system could be overheating and tripping that breaker. Either you need to replace the filter - if it's partially clogged then the motor may have to work too hard to get suction and cause it to overheat. I'd suggest checking the filter first, because that's the easy fix. If it's not the filter, then your motor is going out. You'll want to replace that. Check the filter, and let me know. I'll see if I can find a place to order a new motor for it.
Sep 01, 2007 | Broan-NuTone CV570 Central Bagless Central...
I have the Nutone 353 central vacuum. The last few times we have used it motor has shut down and then will come back up after an hour or so. Re-set switch does not seem to matter
I would try emptying it out and also cleaning any filters you have access to at the same time. It is usually a sensor for heat that stops the machine and if it is getting full or has plugged filters it will get hot fast cool down and then it will do it all again . Hope this helps you. Good luck
Oct 07, 2010 | Broan-NuTone CV350 Performance Bagged...
Vaccum runs for 2 or 3 minutes then shuts off. Can not restart it for several hours. We have tried EVERYTHING with no luck. I see there is the same problem with the VX550...is there a recall on this one...
The VX series NuTone's have had some problems but NuTone is taking care of them as long as it is under warranty. You can contact NuTone at 1-888-336-6151 or whoever you purchased the unit from and you will most likely get a new unit. There are no parts available for the VX units so whenever there is a problem NuTone has been sending new units out.
Oct 06, 2009 | Broan-NuTone VX475 Bagged Central System...
The suction has dramatically decreased
Use an electricians fish tape or plumbers snake
May 15, 2009 | Broan-NuTone VX475 Bagged Central System...
I have a nutone CV-750, and when I am using it, it will shut off and on.. What can I do?
It sounds like you could have one of two problems. I would guess either a short in your house, or a bad relay. If you plug you hose in sideways it will bypass the low voltage wire in the hose. If the unit doesn't shut on and off then you have a short and need a new hose. If the unit continues to cut on and off then you probably need a new relay. The relay is really easy to change out yourself and there are places to buy online.
Jan 06, 2009 | Broan-NuTone CV353 Central Vacuum
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Out of Warranty
NuTone is a very reliable brandname. If you are the original owner and can document that you are, they will more than likely be willing to assist you. I cannot promise that they will give you a "free" replacement; but I can say that it is my experience that they will offer some type of quality help or guidance. ~ TTURAMBAR
Aug 19, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone vx550c central vacuum
You ended chat so fast i guess that fixed ya ??
Aug 09, 2008 | Broan-NuTone VX475 Bagged Central System...
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
490 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
