Question about Samsung LN-S4051D 40 in. LCD Television
Samsung TV won't turn on- trying to fix it. A challenging problem
Gurus, help needed on fixing a Samsung LCD TV (LN-S4051D). The 1.5 year old TV won’t turn on. There is no picture or sound. When plugged in, a click sound was first heard followed by the red LED light blinking 4 times (next to the power button on the panel). Then the click sound came back again with 4 blinks of the LED light. The whole thing went into a cycle while the power button on the panel and the remote are not functioning.
I did some research and followed the suggestions on a “similar” problem brought on this forum. I replaced the IP board (power board) with a new one. The problem still existed. Then I checked all the capacitors on the PCB board (the main board) and found no blown ones. My question is that what is the real problem of the TV, and if it’s worth to spend another 300 dollars to replace the PCB board. (I already spent over 100 bulks on a new IP board). BTW, the TV cost me 1300 dollars when I bought it. Thank you all,
  • 2 more comments
  • Anonymous Jun 23, 2008
    I have the same problem. Anyone knows how to fix it?
  • aurelius1 Aug 06, 2008
    Same deal with my 4051D, it clicks intermittently while plugged in. Does not respond to remote control other than to make more clicking sounds when certain buttons are pressed .. strange.
    Please e-mail solution or advice to me.
  • Anonymous Aug 27, 2008
    I have exactly the same problem that was reported by xiangr on Jun 17, 2008. Same make, same model, 1.5 yrs old, four blinks cycling over and over again but TV never comes on. Our problem started on August 17, 2008. Have not tried anything other than internet to see if there are similar problems
  • Anonymous Sep 01, 2008
    I actually have the same exact problem, I've been reading and there is no other way than replacing the main board. Anyways, since the TV is 1.5 years old, Samsung won't honor warranty.. we should fight it together, this is an actual recall there is no way this is happening and none of us do nothing....
2 Suggested Answers
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
I need a instruction manual for samsung lcd tv model # LN-S4051D
You can download or view the manual at manualnguide.com.You may need internet explorer 8.0 for downloading.
Apr 07, 2010 | Televison & Video
My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
Sep 07, 2009 | Samsung LN-S4051D 40 in. LCD Television
TV clicks constantly, as if trying to turn on/off.
Probably a bad main board or T-CON board or both. If you're trying to fix yourself, try disconnecting the cable (LDVS) from the small board (T-CON) at top center of the LCD panel and see if it still cycles. Note, be very careful with that cable, it is very delicate. If it still is cycling off and on, then it is probably the main board. A slight chance it may be the power board also.
Apr 04, 2009 | Samsung LN-S4051D 40 in. LCD Television
Power wont come on... red light blinks... hear clicks but no pix
There are many reasons as to why the tv can default to service mode (blink codes) and may have nothing to do with the power supply board. Flat panel tv technology incorporate intuitive interrupt circuits designed to prevent catastrophic failure regardless of the boards functionality.
Some root causes to this condition may be:
1 Bad inverter board (step-up hi-voltage CCFL)
2 faulty regulator control board (data timing)
3 faulty interface processing board(s) (signal switching)
4 faulty power supply board (main voltage)
5 Bad LCD driver circuit, or faulty LCD panel its self.
6 faulty scan circuits.
__________________________________
To diagnose and solve these particular circuit scenarios require a professional service technician. Any of the problems above would take around 35 minutes and 100 bucks to repair at a service center.
But if you insist on fixing it yourself I can try to help you determine which board is possibly defective. I do have schematics for this chassis. If you have a multi-meter and 5mhz oscilloscope we can get started. These are the 2 instruments needed to check for critical waveforms and voltages according to the schematic data. It could be any circuit in the tv causing this condition.
The components on the circuit boards that could be defective are as follows:
Diodes
Transistors
Inductors
Resistors
Transformers
Crystal oscillators
Filters
Relays
Transducers
Capacitors
IC chip arrays
__________________________________________
Modular causes to this condition may be:
poor resistance too ground
high current too ground
over voltage
under voltage
over current
under current
shorted switch actuation
___________________________________________
Software related blink intervals:
Parental locks
Sleep mode
Hidden key commands (test mode servicing)
"though if in this blink category the tv should come on requiring password. So this is unlikely....
Jan 26, 2009 | Samsung LN-S4051D 40 in. LCD Television
Sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Dec 21, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Audio is fine but no video
It is the backlight not lighting up. Your probably need to replace it.  I have the same problem, but have not yet replaced the backlight.
Sep 29, 2008 | Samsung LN-S4051D 40 in. LCD Television
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-S4051D 40 in. LCD Television Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
