Question about Cobra 22 CHANNEL 2-WAY RADIOS
I have 4 radios. Initially they all worked together. Now , een on the ame frequency , they do not all pick up the signal? Any ideas why?
  • charlin123 Nov 11, 2010
    I should have added that the pricacy codes are all set the same also. Every setting is exactly the same yet only two of the radios work together.
  • 20 Answers
These are FRS/GMRS radios. You may have different privacy codes set on the radios. If a receiving radio has a different privacy code than a transmitting radio, you will not hear the transmission. This allows many people to share the 22 channels, but only hear transmission from their party.
Posted on Nov 11, 2010
I have a red signal light that keeps blinking in gp328 any ideas?
A blinking red light can be a sign of the radio picking up radio frequency waves (RF) on your same frequency or a nearby frequency. There may something transmitting in your area which is causing the blinking light, or you may have another radio which could be stuck in transmit. One way to check this is to take the radio to a different location and see if the blinking still occurs.
Next, the question would be, does the radio function otherwise correctly? If so, continue to use the radio and do not concern yourself with the light. If the radio does not function properly, they you should send it to a qualified radio repair center for service.
Best regards.
Sep 17, 2014 | Radio Communications
Scanner won,t pick up signals
you need to turn back the squelsh untill the scanner stops and you have to enter the frequencys manualy to get them you will have to go on googles and search for scanner frequencies
Feb 22, 2013 | Radio Shack Pro-95 Handheld Scanner
Unit is an AKG SR40 Dual Pro Wireless receiver, PT 40 transmitter. 662.3Mhz operating frequency. The right side channel is hypersensitive and indicates that it is picking up a signal when the transmitter...
I would suggest that you change your operating frequency. The antenna being removed suggests that the receiver is picking up interference on that frequency. This frequency is in the UHF TV band, and although analog TV no longer exists, digital TV still uses some of the frequencies.
Nov 04, 2017 | AKG Radio Communications
How does it work
Radar detectors are similar to radio receivers that are in your car or home. Radio receivers pick up signals in AM and FM frequencies. Radar detectors find the frequencies that are used by police officials using radar guns. Once the radar detector finds a frequency being directed at your car, it signals the driver somehow, most likely by beeping. It is a simple technology. Although, as law enforcement agencies expand the frequencies to detect speed, companies need to produce more radar detectors
Sep 27, 2010 | ESD 7330 Radar Detector
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
Need to use my car radio frequency for my dvd (make is unknown) player but can't figure out which station!
You want to pick a frequency where there isn't an existing station, so the radio will have a clear signal from the dvd player.
If the DVD player only has a few frequencies to choose from, then tune the radio to each one (with the DVD player turned OFF) and see which one has the most static and the least signal from radio stations in your area.
If the DVD player can be set to any frequency, then just pick a frequency (usually down on the "88" side of the FM band) with the least local signal, then set your DVD player to use that frequency.
Does this make sense? Feel free to ask questions with the "add comment" link.
If this solves it for you, please be sure to hit the "thumbs up" for me!
Feb 09, 2010 | Farenheit DVD-36 Car DVD Player
Cobra 19 DX IV CB Radio Gets no signal at all
my only idea is the frequency that Canadians transmit/recieve on is different than us down south (in the USA). I know Europe and the UK use a different frequency range so my guess is that Canada uses a different radio frequency range than the U.S. making you unable to communicate with fellow radio users. You may be able to search the frequency range for Canada vs. the U.S. and see if there's a difference. Hope this helps...and again, it's just a thought.
Montana, USA
Jul 08, 2008 | Cobra 19 DX IV CB Radio
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Open Questions:
Cobra 22 CHANNEL 2-WAY RADIOS Logo
189 people viewed this question
Top Cobra Radio Communications Experts
Steve
Steve Allison
Steve Allison
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
