Question about Brother HL-4040CN Laser Printer
L have small spots of colour all over the page mainly black not in any one place on the page unable to use sent to clients with all he spots over it it will go away for a small amount of time then return very frustrating
Well, if it's any consolation, I'm having a similar issue with my HL-4040CN. I discovered sometime ago that the problem gets worse if the printer has been off for a couple days or more. So, in order to lessen the appearance of almost exclusively black dots (for some reason, dots of other colors hardly ever appear) all over my documents, I have to keep the printer on all the time. I can only imagine how much electricity this must be wasting (and how much my carbon footprint must be increasing!). Being somewhat of a perfectionist, It is very annoying to see these dots ruin jobs that I would have spent much time perfecting onscreen.
The solutions suggested in the user manual for this printer are useless.
Posted on Nov 13, 2010
Testimonial: "thanks for the help will not be buying a BROTHER printer again when this one packs up As far as l'm concerned this product is rubbish !!!!"
My lexmark x544 gets a black line down the page when i put it in the tray feeder. What do I do?
Is the black mark in the same place on all print outs? If so, it could be that the paper feed rolls may be dirty.
Oct 16, 2014 | Lexmark X544dn All-In-One Laser Printer
Init unable 50
Set the maintenance unit into place, if the planetary arm does not
move smoothly, clean it. purge cam switch harness not connected correctly,correct the connection,purge cam switch broken replace the maintenance unit, gear(s) on the maintenance
unit broken paper feed motor defective replace the engine unit,
power supply PCB defective replace the power supply
PCB. Main PCB defective replace the main PCB.
Dec 02, 2013 | Brother DCP-195C Inkjet Multifunction...
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
Dec 08, 2012 | HP Officejet 5610 All-In-One InkJet...
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
We have just changed the photoconductor unit on our Epson Aculaser CX11NF printer. When we print or copy, we get coloured spots on the right hand side of the page
Oh-ho! The coloured spots are what is known as "traffic lights". To be sure these are the symptoms: You will have a black spot then a slightly larger gap then the three colours regularly spaced, the pattern will repeat every 150mm or so. If you print a black only page then only the black dot will appear, print with any colours and all four dots will be printed. It is caused by a tiny/slight scratch on the photoconductor (PCU) drum (usually caused by mishandling, a loose or foreign object inside the printer or even trying to print on stapled paper!). Polishing the drum using a very soft dry cloth can often help to get rid of the scratch, but remember to keep it away from any bright light as this will damage the sensitivity of the drum. The traffic lights will be in line with the scratch so concentrate your efforts in that area. Also, while the PCU is out, take a good look inside the printer for any loose or protruding objects, rotate the toner cartridges from above with the front cover closed (opening the front locks the cartridge carousel in position). I sincerely hope this helps as the only other remedy is to replace the PCU with a new one.
Jul 07, 2009 | Office Equipment & Supplies
Lexmark printer x6570 unable to allign after putting in new cartr
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Good Luck
Feb 01, 2009 | Lexmark X2470 All-In-One InkJet Printer
My printer now only prints blank pages.
try wiping the contacts (gold colored spots) with a tissue, and after wipe the ink despensing end.
Dec 03, 2008 | Lexmark Z600 InkJet Printer
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
Nov 23, 2008 | HP Office Equipment & Supplies
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Brother HL-4040CN Laser Printer Logo
708 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
