Question about Acu-Rite AcuRite IndoorOutdoor Wireless Thermometer with Two Receivers
My acu-rite keeps beeping even after a battery change. Why?
  • Anonymous Mar 16, 2014
    acu rite 00617 sensor display flashes
  • Anonymous Mar 23, 2014
    How do I set from c degrees to f degrees on Acu Rite
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Posted on Dec 01, 2010
  • taqsim Dec 04, 2010
    Thank you! I don't use mine for an alarm, but the other day it woke me up at six beeping for no reason I could fathom. I just snipped the wires to the round beeping part on the back cover, and no more beeping...also, no more annoying quadruple beep when I put in new batteries. Thank you!!
How to set time on model 13003
Hello
Get into this link. You can get all the details for your clock radio from there.
lib.store.yahoo.net/lib/partshelf/Acu-Rite-00592W-Manual.
Nov 17, 2011 | Acu-Rite Adagio Clock Radio
Lost instructions for my ACU-RITE model # 1097B MAIN wireless thermometer and need to reset it.
I have a acu-rite weather station and it keeps blinking even after changing batteries, is it garbage now or can it be saved
Sep 23, 2011 | Measuring Tools & Sensors
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
The thing keeps beeping and I don't know why. It
typically the battery is not stron enough try changing the battery to a Lithium battery and see if problem persist
Mar 18, 2010 | Acu-Rite Audio Players & Recorders
Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Nov 24, 2009 | Acu-Rite Audio Players & Recorders
Acu-Rite indoor outdoor thermometer (model 00754) with wireless sensor beeps every couple of hours. Batteries are all new, reset repeatedly, alarm is off.
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
Acu-rite atomic clock squeaks periodically, why?
I had the exact same problem, and found the answer on the Chaney Instrument FAQ page. There's no real solution, but here is the explanation:
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit’s ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Nov 10, 2009 | Watches
Acu-Rite AcuRite IndoorOutdoor Wireless Thermometer with Two Receivers Logo
3,039 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
