Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Is the the Monitor Link /DVI on the Mitsubishi Projection TV WD-62327 compatible with a standard HDMI input?
5 Suggested Answers
SOURCE: Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Posted on Dec 28, 2006
falsafat
  • 31 Answers
SOURCE: Connect Sony Vaio Laptop to DVI on Sony LCD Projection TV
try to lower the resolution of the display, to know how please visit the following link:
https://www.microsoft.com/windowsxp/using/accessibility/screenresolution.mspx
< Please Rate :) >
Posted on Apr 12, 2009
SOURCE: Red blinking status light on DLP Mitsubishi TV
how do you get the tv back on when the light keeps flashing
Posted on Sep 10, 2010
SOURCE: I have a 2002 Mitsubishi
I have a 2005 rear projection mitsubishi medallion hd tv.... for some reason the hd channels do not look as HD as they used to... I went to my cable company and got a new cable box... but it is still not a crisp as it used to be. Could it be the settings on the cable box, settings on the tv or could something have gone bad in the tv?
Posted on Aug 27, 2011
I have a mitubishi ws-55313 with a monitor link DVI connection and I have tried to convert that to hdmi for a cable DVR but it doesn't work any ideas?
The monitor link is not a standard DVI connection, it was used to connect a Mitsubishi HD set top box. You can connect your cable DVR using component video cables and get HD that way, up to 1080i but not 1080p
Apr 15, 2014 | Mitsubishi WD-52525 52" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
2My Mitsubishi WD52725 displays a blue screen suggesting to check my inputs and says signal is invalid..checked all the connections and all is good there..any suggestions? Thanks in advance, Nick
What is your input source and which input cable type? If the source is a PC using a VGA cable, what resolution is the computer sending? 480x640. 800x600, 1024x768, 720x1280 (EIA standard) all at 60Hz are known to work but other modes might not.
If you are using a PC to the HDMI port, it will not work. The only HDMI ports that can connect to a computer will be listed as HDMI/DVI and this TV doesn't have that type of HDMI port.
If you are using any other input source, check try another source or channel. (One of my TVs intermittently finds a digital channel 25-9 and gives that message. We have no clue what station is being found but all the other channels are fine.)
I hope this helps.
Aug 04, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Ps3 hdmi to dvi on mitsubishi wd52327
What brand DVI connector and how many pins are on the connector. try a different cable
Dec 25, 2007 | Mitsubishi WD-52327 52" Rear Projection...
HDMI Input problem
Initialize settings by pressing "menu, 1, 2, 3, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the tuner settings
Dec 08, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
242 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
